Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Dark picture The picture slowly gets darker over time. We have replaced the lamp but it is the same thing. Can't watch tv or dvd unless room is dark. Thanks, Brad
  • bradb4geo Feb 22, 2008
    Thanks, several other folk we know in other parts of the Country gave us the same advise. I will let you know how it turns out. Thanks again, Brad
  • Anonymous Feb 28, 2008
    We cleaned the mirror and the picture is clearer but not brighter. I guess replace the lamp again or get a different TV. They shoudl really have better customer service, we get not response, phone, email or written. But it wont be a Mitsubishi or anything else Mitsubishi.
We did this and it helped with cleaning up the picture, but not the brightness. I guess we will replace the bulb again... or just get a different TV. Very frustrating. Never a Mitsubishi again, TV or anything else as their customer service is so bad. Effectively no help, no even a response.
Posted on Feb 28, 2008
    Sergeant:
    Champion:
  • 301 Answers
Take the screen off by unscrewing all screws around back of tv. remove panel with a sticker that says " no user serviceable parts inside" remove both screws on each side of screen at bottom with black tabs. there will be 2 screws behind the panel with the sticker on it and unplug the front panel buttons connector. then clean the small mirror with very soft cloth maybe nice cotton t-shirt. be very careful not to scratch the face of the mirror. i would recommend ussing just the cloth but have found isopropyl alcohol to work well if you need to use any liquid.
Posted on Feb 22, 2008
Why is the picture on my RCA tv goes slowly darker as i watch it?
Contact any service technician. Its CRT base connector socket, or, LOT is faulty. This is not a user repairable fault. Replacement to any one among component stated above, or both, might need replacement. Gopakumar Gopalan Google
Mar 05, 2014 | RCA Televison & Video
Ws 55859 has audio but picture is black
This unit does not have a lamp, but 3 CRT's. Odds of all three tubes failing at once is very remote. I would look at the voltages that run to your CRT boards and see if they are low or have a load. You should also check your circuit boards on the bottom of set to see if the CRT's have been leaking glycol. If the board looks wet ot corroded, you are dead in the water.
Mar 20, 2013 | Mitsubishi WS-55859 55" Rear Projection...
I have sound on my tv but no picture
This sounds like the back-lights have quit working. This is made up with an inverter (ballast) and fluorescent lamps. I want you to try something. In a very dark room turn the tv on and watch what happens to the screen. There is three things that can happen. first the screen will stay completely black. This means the inverter never fired, and this is usually a failed inverter, but sometimes the power supply may fail. there is also a rare time the main module never outputted the signal to activate the inverter, but this is rare because you can hear the audio. So obviously the main is working at least 90%. The second thing that can happen is the screen will light for a split second then go black. This usually means that you have a bad lamp. These lamps are physically locate inside the LCD panel, and the replacement cost exceeds the price of a new unit. You may even see a dark area in the screen. The slight glow will not be uniformly lit through out the screen. Finally the last thing you may see is the screen has a slight glow. This means the back-lights work, but the video portion isn't showing. This usually means the driver board (T-con) has failed. This is probably not available separately, so you must replace the panel to fix it. And like before, the replacement cost exceeds the price of a new unit. One more thing to do when the set is on and in the very dark room if the screen is black, point a very intense flashlight into the screen. Put the flashlight against the lcd screen and see that you have video moving around the glow of the flashlight.
Sep 12, 2012 | RCA 22LA45RQD LCD TV/DVD Combo
The TV has a section of it that is dimmed out and darker in brightness. Is this the Main Board that needs replaced?
Check the CCFL lamps used in the backlight section. These camps can cause this type of fault, as they are very like the flourocent tube lights that we use to illuminate our room. As it goes older, the ends of them will get burned, and the intensity will go low. Like ways is to the CCFL lamps to LCD tVs tool CCFL is the abbrivation of [Cold Cathode Flourocent Lamp]
Jul 12, 2012 | Vizio 55" M550NV Razor LED LCD HDTV, 1080p
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
Dark picture on my Philips 50" DLP HDTV
You will need to replace the lamp. That is the only thing that will cause the picture on a DLP to go dark. Please take a few moments to rate my answer. Thanks....
Nov 19, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
298 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
