Question about Refrigerators
Water buildup on the middle rear top shelf of refrigerator
Everyday there is water in the middle rear of top shelf I pulled the freezer plate and defrosted the ice underneath but can't seem to unfreeze the drain. How do you defrost that little drain line? This is a Kenmore
Refrigerator with freezer at the top.
    President:
  • 1,891 Answers
You need to use a turkey baster/ hot water and force it down the drain . this will help . but it will freeze again . so stop bu your appl parts dist and pick up a defrost tube heater kit pt # 819043 . "heat probe .add - on to stop tube ice-ing..) and wa-la your problem is over . make sure the prob is attached to the heater good or it will not trans the heat to the drain properly . mm hope this helped ,mm / feed back pls ..
Posted on Feb 04, 2010
Refrigarator leaking inside
Most freezers have a drain tube behind the back panel. To drain water from defrost mode. This tube freezes up and won't drain. Causing water to drip in the refrigerator making a mess on the shelf. Remove the bottom plate of the freezer remove the back plate. There is a piece of aluminum with a whole towards the middle this is the top of the frozen drain use a turkey baster and hot water to thaw this line out when it is thawed the water will run down into a tray under the fridge. no need to dump it it will evaporate. But you can pull it out to make sure you're hot water is going all the way down. I hope this is helpful.
Apr 03, 2013 | Refrigerators
Water is leaking onto top shelves of unit
Hello, Thank You for using FixYa. I will be helping you today. Your drain line is most likley frozen. You need to remove the shelfs from the freezer and the bottom slide out panel. Remove the screws holding down the plastic bottom piece in the freezer then remove the back panel in the freezer. Remove any ice buildup you can. The drain is in the middle under the evaporator. DONT TOUCH the evaporator. Use boiling water and pour it in the back untill the drain runs free.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | KitchenAid KTRS19KK Top Freezer...
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
