Question about Toshiba SD-3960 DVD Player
Toshiba SD 3960 DVD player
I have a Toshiba SD 3960 DVD player. I insert a DVD and the display shows 0's going across it over and over but it won't play it. I've used a DVD cleaner on it and nothing works.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
"No" message appears on player front.
Try inserting a cd, almost all dvd players can play cds as well, if it displays the same message you may very well have a defective dvd player, if it plays then you may have a damaged disc. If it plays the cd try a mint condition dvd; also, I'll assume that you know better but in many cases if the dvd player is not defective users are simply loading dvds in upside down. If all this fails return your dvd player to the store or check the warrenty.
I hope this helps, good luck
Jul 23, 2009 | Toshiba SD-K760 DVD Player
I want to make my UK DVD player play DVD's from N America.
Try the following procedure
- Power On
- Open Tray
- Press 9879 0 (0 stands for Multiregion, you may press buttons 1 to 6 to choose a specific region)
- A Message appears stating that "The Reg.No was changed to: [insert whatever region (0-6) you selected here]"
Cheers
Dec 03, 2008 | Toshiba Televison & Video
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
Toshiba SD-3960 DVD Player Logo
417 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
