Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
Says there is an I/O error what is this and how do i fix it? i have 536 GB of stuff i can't access!
  • 755 Answers
You may have a damaged convertor board inside the drive housing.
I would check with My Book and see if they are having any issues with this unit and what they recommend for repair.
Otherwise, an at home fix would be to remove this drive from the external case and put it in another one. OR put it in a computer as an accessory drive!
Posted on Feb 03, 2010
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Memory card error
This seems to be a known issue with the Canon camera's to display Memory card error.
Give this a try
1. Remove the card from camera and wait for sometime ( 1-2 minute ) and re-inserting the card.
2. If this does not work, you need a card reader to read/view images on your PC ( since you are not able to access the card in your camera )
3. If you are not able to access/view the images from Card, click on the link below to recover the images from card - Recover images
When you open the webpage, click on the Download Now option to download the software ( it is free )
4. Try this fix to resolve the issue, Sometimes it takes long time for the camera to load the images and it results in memory card error - Click on the link to download the fix - Firmware Update
5. Try using a SD card with less memory like 1 GB card or max 2 GB for better access of card in camera.
Hope this is helpful.
Nov 05, 2010 | Canon PowerShot S3 IS Digital Camera
Naxa NX 538 parental reset code
I don't see the model you've listed on their site. I did find a manual for a 536 model here... http://naxaelectronics.com/app/webroot/img/manual/NX-536.pdf
I would guess the operation is the same to fix it. Good luck and leave feedback! Thanks!
Oct 12, 2010 | Televison & Video
WD5000 My Book 500 GB -- I/O error cannot access
i had exactly the same problem with a WD 500gb External HD MyBook Edition USB , eventually opened up the case removed the 500gb Caviar disk put it in an external HD Case (AC Ryan's AluBox)
and still had I/O error !!! i had serious music projects and stuff i didnt want to lose , after lots of research and looking around this program SAVED MY LIFE AND ALL OF THE STUFF IN THE HARD DISK !!!!
Ontrack EasyRecovery Professional v6.20 retail first i run the simple in-depth diagnostics then i used the EasyRecovery DataRecovery option and after about an hour of scanning started copy-pasting all my files onto another disk ! this app saved my life a special thanks to its programmers ! im John from Greece , hope this helps bro!
Nov 28, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Http://db2.t.msn.com/en-gb/home.aspx?ver=8.5.1302&did=1
First let me explain. Each browser handles scripts (the stuff that make up web pages and stuff) differently. You have Notify Me of Script Errors turned "ON" on your computer, so you will be notified of every error or warning - even if it works fine.
FIX: To fix this, Go to your Control Panel (START > Control Panel) and, in Classic View (you can find that on the left panel), click Internet Options. In the tabs on the top, click "Advanced", and then find the category "Browsing". CHECK "Disable Script Debugging (Internet Explorer), and "Disable Script Debugging (Other)". UNCHECK "Display a notification about every script error".
Click OK, and then messenger should work fine. If it does it again, restart your computer, then it will work fine.
Nov 26, 2008 | Microsoft Windows Vista Home Premium with...
IOmega backup drive 80 Gb
try to do some tune-ups for your hard drive like scanning for disk errors and defragment it...
Jan 21, 2008 | Computers & Internet
Lacie 250 gb gives error while accessing some folders
I took mine to a place to get it fixed and they said it was beyond repair and the only option is to recover the data and transfer it onto another disk
Jan 18, 2008 | LaCie (300728U) 250 GB Hard Drive
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
