Question about Saws
I have aStihl TS 400 cut off saw. The outer Shroud was removed to replace the spark plug. I did not remove the shroud, someone else did for me, now I cannot figure out what parts are attached and to where they are attached. I need a schematic with a blown up view I guess. Nothing obvious to this.
  • 23 Answers
Stihl doesnt publish anything online they want you to go to the dealers. i used to work for one and if you go in and ask most of the time they will print it right out for you or if you get lucky theres a good mechanic in there would waiting and can show you real quick.
Posted on Mar 04, 2010
What is proper spark plug gap for Stihl TS 400 Saw?
BOSCH WSR6F
Part number 1110 400 7005
or
NGK BPMR7A 4626
Part number 0000 400 7000
Apr 04, 2016 | Stihl Saws
Removing the shroud to get to the spark plugs on 2013 Chevrolet Traverse.
The easiest way to get them out is to use a PICK and get under the Edge. Some will BREAK... Get some Spares.....
Apr 06, 2013 | E3 Spark Plugs Motorcycles
Frigidaire FRA064VU1 repair
Hello, yes once you remove the outer housing it should not be difficult to snap or fasten into place.
Jul 06, 2012 | Frigidaire Fra064vu1 Air Conditioner
Does my dp46840 need the shroud over power supply?
Not likely. The shroud is used for keeping out interferences. Not your case tho...
Jun 11, 2012 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
Hi, my Stihl ts 400 blade runs at idle.I have tried adjusting the idle down as far as I can but it still turns.
seems that ur clutch is sticking.take recoil caseing of and check by turning blade by hand,if you feel the engine turning over,then your clutch drum is sticking,be sure to remove ur spark plug cap! it will be the bearing at the rear of the clutch drum,maybe a little oil and a few turns will help it free itself.hope this helps.
Dec 06, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
TS 350 I have spark to the on/off switch, but no spark to the spark plug
The Short Circuit wires need to be looked at. Take off the cover over the flywheel. The two thin wires coming off of the coil need to be checked to see if there is a spot that has rubbed off and if there is a bare wire grounding out against the housing of the Cut Off Saw. May also check the coil wire going to the spark plug. This can also develop a spot that can ground out on the housing.
Sep 17, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
My ts 400 cut off saw has no spark when trying to start it
check to make sure it not the saw it self. remove the flywheel cover and remove the wires from the ignition module(do not remove the spark plug wire) then reinstall flywheel cover making sure wires will not get caught in flywheel. using a ignition tester see if it has spark. if not replace ignition module. if it does however that means now you have to track down where the short is.
Feb 11, 2010 | Saws
How do I replace the spark plugs on a 2001 Dodge Dakota? There is some type of metal cylinder around the spark plug, preventing me to get my socket to grab on to the spark plug.
is it a shroud that covers all of them i know some models it takes a special plug socket to remove them its very thin in diameter so a special socket is used or if possible like i said if its a shroud remove this to gain access
Sep 07, 2009 | 2001 Dodge Dakota
Saws Logo
117 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
