Question about Acer Aspire One PC Notebook
My Acer will not turn on. the battery is fully charged.
    Problem Solver:
  • 32 Answers
I have this problem ,the power on is bad ,you can click it last the power light onor you can look world of warcraft accounts and buy world of warcraft gold
Posted on Feb 04, 2010
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Acer Aspire One won't turn on or charge, totally dead. DC power pack tested ok.
You probably get damaged the charging connector, or it is simple dissoldered from the mainboard, thats a very common problem. Check first if it turns on with another fully charged battery. If yes, you should resold the charging connector.
May 14, 2011 | Acer Computers & Internet
How long to charge laptop the first time?
it will take 4-6 hours to charge the laptop full time...
Jan 20, 2011 | Acer Computers & Internet
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Aug 27, 2008 | Acer Computers & Internet
Acer n30 will not turn on
Trya hard reset, mine was off for 6+ months and wouldnt charge. After a couple of hard resets - bingo, fully charged battery.
Oct 31, 2007 | Acer n30 Pocket PC
Acer Aspire One  PC Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
