Question about T-Mobile Sidekick ID Cellular Phone
I press the roller ball down to click on something and it does nothing i have to press it hard and many times to click on anything
  • 49 Answers
Dirt, dust and other stuff can get under the senors of the trackballs on sidekicks and blackberrys causing them become less sesitive to being pressed. We offer repair soultions for this problem. Typically to repair this it costs $30. We warranty or repairs for 90 days and we offer free return shipping. Please call us if you are interested.
Spring Service and Repair 720-274-2492
555 Broadway Denver Colorado 80203
Posted on Feb 03, 2010
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
Tip
How to Clean Your Mouse
<p><b><span>Roller Ball Type:-</span></b><br /> <p><span>For cleaning your mouse you have to do the following work.</span><br /> <p><span>1. Disconnect the mouse from your computer CPU.<br /> 2. Turn the mouse upside down and twist the roller ball retaining ring in a counter-clockwise direction to remove the ring.<br /> 3. Remove the roller ball from the mouse cavity.<br /> 4. Wash the roller ball with warm soapy water and put it in dry place.<br /> 5. Replace the dry roller ball back into the mouse cavity.<br /> 6. Replace the roller ball retaining ring and twist it clockwise to tighten.</span><br /> <p><b><span> </span></b><br /> <p><b><span>For Laser type Mouse:-</span></b><br /> <p><span>A laser type mouse requires very little care. Internally, there isn't anything required of you. If it should get a little dirty on the outside, just dampen a soft cloth with water and wipe it until it is clean.</span><br />
on Dec 24, 2010 | Computers & Internet
Roller ball quit rolling
Hi there, it's Jack at Dyson.
If the ball doesn't seem to rotate as normal, this is likely to be because the HEPA post-filter is out of position. Please take a look at the video below which shows where this filter is located, and how to remove and replace it.
Press the filter firmly into place until you hear and feel a click.
I'm confident this will resolve the issue, but if there's anything further we can help you with you're welcome to contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Feb 19, 2014 | Dyson DC25 All Floors Bagless Upright...
The red button at the side of the roller brush to reset it on my dc24 rollerball doesn't seem to do anthing. What am I doing wrong the diagram shows that you push the button forward but I can hardly get my...
you need to use something small to push the red pin right in, make sure there is nothing blocked in the roller and this should reset the motor. The roller needs to be switched on next to the power button is well.
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My roller ball does not scroll down, it goes all other directions but down, it makes it so hard for me to navigate.
take the roller ball out by poping out the silver ring at the top and look on the bottom of the ball and make sure that all of the black rollers will roll and if not clean them.
Feb 22, 2010 | AT&T Blackberry Curve 8300 Smartphone
Curser jumps all over the place,hard to drag anything and sometimes it double clicks
If this mouse has the roller ball, the rollers it runs on are dirty. Remove the ball and use a q tip to clean all three rollers the ball runs on.
It is also possible that the cable to the moise has broken. This occurs where it flexes.
A person experienced in electronics can shorten the cable slightly to get rid of the bad section.
Dec 01, 2009 | Dell U0636 Mouse
Trackball will not go down. Pearl 8100
It has been in my experience with the 8100 that if you can't scroll a certain direction, there was debris on the roller preventing it from registering the roll. Turn the phone off, press down on the track ball (as if to press a button) roll the ball down (in your case). This may help dislodge whatever debris is caught in the roller. It has worked for me several times. You may want to try and clean the trackball as well with some rubbing alcohol and a q-tip.
If it were a software problem, then I would imagine you turning off the phone (battery pull) would clear this up anyways.
Best Regards,
Bill
Sep 02, 2009 | RIM BlackBerry Pearl 8100
Roller ball
All you have to do is take a sheet of paper with print on it. Take the battery out of you phone. Next do a figure eight motion with the ball side down on the phone about 10 times. There is something on the ink on the paper that will make this work again. good luck
Feb 12, 2009 | Verizon Communications BlackBerry Pearl...
Sidekick 3 keeps locking up
Go to setting then go to system info....then press
Menu +shift+x
Then it will ask something...and press yes
Feb 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
T-Mobile Sidekick ID Cellular Phone Logo
138 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
