Question about Sony DVP-PQ2 Portable DVD
How can i change it to riegn free
I have a sony dvd (dvp-pq2) how can i change it to riegn free
3 Suggested Answers
otacon
  • 1944 Answers
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
From which region is your did player?
Posted on Apr 14, 2008
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
I have a remote for sony tv RM-Y167 and need to program sony DVP-S530D CD/DVD player code
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jun 21, 2014 | Sony DVP-PQ2 Portable DVD
Region
You maybe able to get a Region free code from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 13, 2013 | Sony Dvp-ns710h
Hi, I have a sony portable dvd player (DVP-FX730). Is there any way I can make this region free? (currently region 2)
I'm afraid, there is no way to change region code in Sony dvd players including DVP-FX730
I'm sorry for that.
Thanks.
Mar 09, 2011 | Sony DVP-FX730 Portable DVD Player
Need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at sonyhelp@selen.org and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Feb 10, 2009 | Sony DVP-NS575P DVD Player
Sony DVP-PQ2 problem
does it do this with every disk?
it could be one of several things, with some of these drives it uses a friction wheel at the center of the disk to "spin" the disk, this uses a circular rubber traction disk to grip the disk on both sides and then spins the disk using this traction, ( if the rubber there is not good it will not work well)
the other kind of spindle is a press on spindle which has a spring loaded grip mechanism where the disk is clipped onto the spindle,
the other issue is that you may have a driveband failure, this basically a rubber band which drives the main drivewheel from the drive motor, these can wear out or perish.
lastly, it could be a bad/burned out drive motor,
all of these issues can be fixed by the manufacturer and some of these can be fixed relatively easy by the user if the unit is out of warranty
Oct 13, 2008 | Sony DVP-PQ2 Portable DVD
Region Codes
It works for NS50P, NS575 and the most models of the families NS50 e
NS500.
With the DVD player turned off(stand by), press:
TOP MENU
CLEAR
POWER
Choose option 2 and after option 4. Type:
12450 [press enter]
00000 - Then press enter and power off.
DVD will now be region Free.
Jan 07, 2008 | Sony DVP-NS50P DVD Player
Sony DVP-PQ2 Portable DVD Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
