Question about Bunn CWTF 15-3 Coffee Maker
Our Bunn CW series three burner is over filling. How to correct the problem??
    Problem Solver:
  • 18 Answers
Needs service tech to adjust.
(Do it yourselfers can adjust the black knob down from 2.5 to about 2 mins. Digital timers have instructions in back of the front panel. CAUTION!! There is high voltage present. Pull out the plug! Safer to just have it serviced.)
Posted on Feb 10, 2010
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
I have a bunn CW series brewer. I filled the reserve with water and allowed to get hot. I then add additional water (1 glass pot) and it just starts to dispense without me hitting the "start" button. I...
Sounds like the switch is stuck in the operate position. Therefor once the machine hits temperature it just brews. Your local Bunn distributor should be able to recommend an engineer to replace the switch or supply the correct t,hope of switch if your confident enought Tom replace it yourself.
May 11, 2014 | Bunn CW 15-APS Coffee Maker
The brewer is on a gravity feed system, after the initial fill, whatever you put in is what comes out. as for the start button check the water connection on the back, there might be a problem with the solenoid.
Bunn CW series slow water flow
delime the sprayhead and the reservoir drain in the top with a deliming spring or a screwdriver
Dec 03, 2012 | Bunn CWTF 15-3 Coffee Maker
CWT 15-APS Coffee Maker: How do I get into the back of a CW series brewer t...
You have to get to it from the front panel. Remove the 6 screws for access.
May 18, 2010 | Bunn CWT 15-APS Coffee Maker
The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Aug 14, 2009 | Bunn NHB Coffee Maker
Our Bunn CWTF15 three burner is over filling. What can we do to correct this problem?
There is a timer inside the front panel re-just the timer with an empty coffee pot right up to the top edge with water only.
if not successful let me know and I'll go further with your problem.my email address dickson@lau.com
God Bless have a nice day.
Dickson
Jul 02, 2009 | Bunn CWTF 15-3 Coffee Maker
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
WATER NOT HOT
This is caused by one of three things - either your limit high limit thermostat is gone, your thermostat is sticky, or your element died. Try turning your thermostat up or down a little bit. if your thermostat is stuck, this will usually start it again. Look for any burnt wires as well, because sometimes they will burn off of a contact.
Jan 27, 2009 | Bunn CWTF 15-APS Coffee Maker
Bunn CWTF 15-3 Coffee Maker Logo
566 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
