Question about Remote Starter with Keyless Entry
Just installed the starter, and after starting it with the remote, it shuts off after 5 seconds. whats wrong?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Make sure the tack wire is hooked up and program
Posted on Feb 04, 2010
I have a 2004 Ford Ranger and when I try to remote start it, it starts but it sounds like its trying to start it again and then shuts off
If the truck starts fine with turn of the key in the ignition,look into finding the problem with the remote starter system.
Components maybe faulty or not proper.
Module.( Hidden underneath, usually somewhere under steering column area)
Receiver/Transmitter.( Mounted inside vehicle windshield )
Switch.( Under Hood,usually on the top radiator support bar )
Wiring.( all connected to the Module )
Fuse / Relay.
Remote / programming/ remote battery.
Connections that maybe loose,corroded, loose or wrongly connected.
Its also possible your vehicle might need a by pass module to connect with the remote starter module, to enable vehicle starting by remote.
Have a nice day.
Apr 17, 2016 | Vehicle Parts & Accessories
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
Can I get the installation wiring diagram for remote starter viper where can this be found
1998 Cherokee?
wow , old bendix starters ,they are long long gone, (done many)
a blast from the past. LOL
so is this an after market hacked in Remote?>
sure.
well buy a new system and read the instructions.
if using an old system , get the instructions online, at makers web site, we can not guess makers, of anything aftermarket.
it hangs up the starter solenoid, , and is very dangerous to you , like that. sure.
my guess is the control (in car) is bad, shorted relay in box or transistor that drives the small wire to the starter, or to cars starter relay .
the starter relay is in the USA PDC fuse box.
all answers USA , not export jeeps, this is a USA forum (calif)
Feb 08, 2015 | 1998 Jeep Cherokee
2009 dodge grand caravan 3.8l. remote starts vehicle then shuts down after 5 seconds whats the solution
sounds like your factory alarm is not working with the remote starter. it happens a lot with the new cars. check the BCM that runs the factory alarm.
Dec 15, 2012 | 2008 Dodge Grand Caravan
When the remote start button is press the car will
Chek the inmobiizer bypass connections if you are not using it chek the tach wire and also perform a learn tachometer.
Mar 18, 2010 | 5000RS-2W-1 Remote Starter with...
Bulldog Remote Start Problem
if thats a key resisor bypass i never heard of that, i would check with with bulldog to see if may be a set upproblem
Jan 24, 2010 | 2000 Chevrolet Impala
Remote starter problem...
Either tach is not learned or tach wire is hooked up wrong
May 26, 2009 | UltraBac Software Remote/Local Server...
Why does the car start by itself after I installed the remote starter?
i could be to things, if the remote start has a remote timer, that you can program the remote start to start every hour for like 5 minutes, or there is an activation wire on the remote start that is getting grouned somehow and allowing the car to start. What i would do is look in your manual and see how to bring the remote start back to all its original factory settings, and make sure all loose wires are taped up and not touching anything. If you need help on manuals or anything let me know and i can walk you through it.
Feb 27, 2009 | Avital Vehicle Parts & Accessories
Remote Starter with Keyless Entry Logo
134 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
baire
john h
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
