Question about Malber P21 Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Posted on Feb 03, 2010
Testimonial: "quick response. The answer makes sense and probable will have to be done at some point, now Im cycling it with bleach and water softener and praying!"
Zasounussi problems
on all front loaders, the smell comes from not been used every day, #1, and water sit at the bottom of the drum, is always water in the system from the top of the drain hose to the pump, and they, the manufacture recommend that you use some chemical once per month to clean the unit.
this is what I do. get a bucket of water and bleach 3 water 1 part bleach, get a rug that you do not need any more. wet the rug and with your hand open the door and put the rug unter the rubber around the glass door, in other worth's, the rubber that connects the door to the drum bucket rinclos and water and other material stays there, building mildew, would be good to wear a globe, and clean the inside of these rubber real nice, go around several times to make sure you don't miss a spot., the cloth well come out black means it is loaded. then put the rest of the water and bleach in the machine, add 2 caps of bleach in the machine, fill it to hi and let it stay for 1 hour or more in the drum, then have a gentle cycle, these well clean the rest of the unit. one more thing, if you have members of the family that forget coins or papers in they pocket. may have to do more work to clean and drain the unit, just let me know I well help you.
Apr 14, 2014 | Washing Machines
Washing machine is shutting off after a rug was washed in it...I didn't know it would desinigrate now it won't drain and keeps shutting itself off.....what can I do?
time to empty out the pump filter trap .....never wash rubber backed rugs in any washer!!!! we call them washer brakers ....
Jan 28, 2011 | GE Washing Machines
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Whirlpool Duet won't stop draining
The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.
In talking with the customer, I found out the last load before all this started to indicate a problem was a rug from the house. Rugs can be troublesome to was as many of them used in laundry and bath rooms have rubber backings that can come loose when washed. When the backing comes loose, it can find it's way into the drain system and cause a problem, or the rug fibers can come loose and do the same thing. Figuring this was the problem, I explained to the customer how to get access to the drain pump by removing the three screws that hold the lower access panel in place. Here you will find the pump and the all important sump clean out, or as we like to call it, the coin catcher. Inside she found many fibers from the rub along with a few other things that found there way out of her kids pants pockets.
With the sump cleaned out, I asked her to try another load then to give me a call and let me know how everything worked out. A phone call a couple hours later told me the problem had been solved, and now this customer knows a bit more about her washer.
Many of the front load washers on the market have a user accessible clean out for just such an occurrence. Just be aware that if you open it up, any water that is still inside the tub will quickly be in your lap, so plan accordingly.
Feb 09, 2009 | Whirlpool GHW9100L Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Water in machine under bucket
your outlet hose put it down close to the floor into a bucket if water comes out then your pump may have blown if not it will be blocked up u may find if u take the outlet hose of water may come out which means your pipe is blocked
Aug 12, 2007 | GE WJRR4170E Top Load Washer
Malber P21 Front Load Washer Logo
365 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
