Audiovox FPE3206 32 inch HD TV. After power is turned on the blue light illuminates but the picture screen flashes to the initial Audiovox display and then back off again. the sound also squaks with a power on/power off type sound. The system repeats this process and does not start the tv. I was able to trick it on a few times pressing the sound increase and decrease button while it was attempting the power up. I disassembled it and checked the power supply. I found no obvious damage- electrolytic caps are within 10% and diodes all hold forward voltage. Ideas?
  • bobby_mcquai Feb 04, 2010
    At what point on the inverter board are the voltages tested? This solution seems feasible but your justification raises more questions than it answers. If voltage is provided off board, then it wouldnt be the inverter but the supplier of the voltage. If voltage is on board conditioned then I wish to test for that PRIOR to ordering a $159 part.
  • 4,889 Answers
The quick flash and the on-off sound(Clicking noise isn't it?) indicates a faulty relay on the power board. A component level repair might be possible but you are going to need a service manual for this one more so its the failed protectors that knockout the relays more often than not. A component by component voltage/resistance measurement and comparing it with the values in the service manual are critical for this repair.
Unfortunately I don't have one for this model. See if you can find one online.
Sai.
Posted on Feb 05, 2010
    President:
  • 2,923 Answers
You could have a bad inverter board.
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.The inverter must be tested by reading voltages with a multimeter.
For this case, it would be best to contact the manufacturer or have a local repair tech to check it or replace the bad component for you.
Good luck and have a great day!
Posted on Feb 04, 2010
Could the Main Logic Board in my Sony Bravia Ultra HD 4K XBR70X850B be bad?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 24, 2016 | Sony Televison & Video
AUDIOVOX fpe3707hr power lights up blue screen but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 07, 2017 | Audiovox Televison & Video
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
I have a jvc lt-26a6asj tv blue power light is on but no picture just black screen when turn on and off get a flash of picture but then goes to black screen
hi, the most probably is broken one of neon lamps that illuminates led display .you can check that when you turn it on and flashes, see if one side of screen is brighter then other. also,it can be that power supply in led display got weakened and haven`t got enough power,but that is job for service like any bigger failure.
this is not the only answer,there is always several solutions but you have to give more informations about malfunctions. good luck!
Feb 27, 2011 | JVC Televison & Video
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
Red and green
It might have HD set on if you dont have HD on TV
the swich to do no HD is on the cable that hooks up 360 to to
Sep 23, 2008 | Video Game Consoles & Games
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
