Question about Compaq Presario 5000 PC Desktop
My compaq desktop has two long beeps a pause and two long beeps without a signal to the monitor. If I put a recovery disk in it beeps normally but still no screen.
    Sergeant:
  • 206 Answers
Sounds like a video adapter problem. Try taking your video card out and then reseating it into the PCI slot. Make sure your monitor is connected correctly. Also, it might not hurt to make sure the all other periphs are seated correctly. (RAM,Network card, etc) hope this helps
Posted on Feb 04, 2010
Trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
Oct 05, 2013 | HP Compaq Presario SR1115CL PC Desktop
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
The PC powers up, then starts beeping, one long beep and one short beep. The monitor tries to come on but shows the DVI with no signal; and the HDMI with no signal and the VGA with no signal and then the...
the beeps codes means there is a problem with a piece of hardware (RAM, or graphics card ,etc)
I need to know the BIOS manufacturer to interpret the code (phoenix or award or AMI)
for COMPAQ it means BIOS error --and will have to reload it from a recovery cd.
for IBM it means system board failure-- need new mobo--for a beep code of 1 long and 2 short most all mean graphics card problem.
If this was helpful, please indicate so, if not , comment back so we can resolve this issue
Dec 27, 2010 | HP Computers & Internet
I have a compaq presario sr1500nx and i want to restore it to factory settings.The problem is I was told i needed a disk and i cant find the disk.I was wondering if I could restore it without a disk or...
1.The first option is you can try to restore it from F11 the hard drive partition...Shut down the comp and then restart it and keep tapping the F11 until you get a screen that says Recovery manager...
2.select the system recovery option if available...click on next...
3.choose whether you want to backup or do recovery without the backup...click on next...
4.Unplugg all external devices apart from keyboard mouse power cable and monitor...
5.then click on the next button...the recovery will start...
6.If this option is not available...disk's are the only option...
Oct 18, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
My optima with asus P4VP-MX will not start up. It has been in storage for a long time ,but was working when stored. Fans start,green led on, hard drive clicks, power to mouse, lights flash on keyboard,but...
do a system recovery Asus computers system recovery can be done using the recovery disk that comes with the computer or it can be done by pressing F9 on the computer keyboard upon boot up.
Jul 25, 2010 | ASUS Computers & Internet
I have a Dell 1720. It does not boot normally. I
Does the Dell laptop have recovery software. If it does, here's a way to overcome the problem and make your own set of recovery disks.
When you do a destructive restore, it actually rolls back all of the software, including the recovery software so you can actually make a set. At this point, it will fix all of the software issues.
Jul 25, 2009 | Computers & Internet
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
Boot up problems
If it won't go past the splash screen, and you have replaced the CPU, I agree that it is probably the motherboard.
One other test you can do is, remove the memory chips, and any cards that are plugged it, and see if it beeps on start up.
If it does, count the beeps. If it doesn't it is the motherboard.
If you get beeps, plug the memory back in, and try again. Listen for beeps. Let us know what you find.
And I don't know if Compaq's do this (Dells do) when you turn it on, do the fans spin up normally? Or does it sound like a small jet? Speaking of which, do you see the fans spin up at all?
Aug 05, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
Compaq Presario 5000 PC Desktop Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
