I have a david eden set up eden 550 amp xl 4 10 cabinet six string ken smith looking for the best set up for my amp that will give me the cleanest signal for church and R@B music what should my eq and levels be HELP i have problems with a distorted signal it should me much cleaner
    Top Expert:
  • Audio Player... Master
  • 78,267 Answers
The solution of this problem almost totally depends on the acoustics of the room this is played in and each particular song or musical passage, there is no one size fits setting, I will give u this tip, try and keep the base low, it is the single biggest cause of distortion, just use enough base so the passage deson't sound "tinny" use the mid-range to add depth and use moderate high end levels, run the volume no higher than needed for sound dispersion to the entire room, make sure u have heavy wiring to the speakers, many times excessive resistance to the speakers caused by inadequate wire size can cause distortion.
Posted on Feb 03, 2010
Tip
Smith Corona Office XL Manual Download
Models: Smith Corona Office 2000 / Smith Corona Office XL
Download Smith Corona Office XL Manual
Have you misplaced your Smith Corona Office XL Owners Manual?
Would you like a digital, searchable, pdf version of the Smith Corona Office XL Users Guide?
Follow this link
to download a pdf version of the operations manual.
I hope that helps.
_____________________________________________
Smith Corona Wordsmith 100 Manual Download
Smith Corona Wordsmith 200 Manual Download
Smith Corona Office 2000 Manual Download
Smith Corona Display 1000 Manual Download
Smith Corona Spellmate 500 Manual Download
Smith Corona Memory Correct Manual Download
on Apr 24, 2010 | Office Equipment & Supplies
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
Amp loosing power
The Eden has a thermostatically controlled fan, my first thought is to clean the fan and airways and make sure it is working properly. This relates to some heat problems on solid state stuff. If they get too hot, some shut off for protection, the fan should automatically speed up on this model to compensate. When volume is low watch the fan. Also, make sure the impedance switch is set properly. I've very rarely seen any reason to use 2ohms settings. The only way to run that is with 2 4ohm cabinets in parallel. If they are in series it would become 8ohm. Any other way will make the amp get too hot on 2 ohm setting. Most cabs are 4, 8, and 16.
Mar 05, 2013 | Eden WT550 World Tour Bass Amplifier Head
Cut out on one occassion & how often does amp need service
Hopefully not often. They are very complicated in design. Keep ALL airflow paths clean and if in a cabinet, give adequate air movement... use a fan if necessary to vent the cabinet. The unit has a string of diodes to adjust the quiescent current in the power amp and if you overheat the unit it will try to protect itself by shutting down.
Jul 25, 2011 | Peavey Pv 2600 Power Amplifier
I'm having difficulties with my rig. I got 2 112xlt David Eden Cabs. Powered by a WT400. For some reason when I hook up the second cab it loses some low end and doesn't get any louder. any...
swap speakers to compare that the second speaker by itself is the same as the first. Next thing is to verify the phase. If the speakers are at different distances from the listener, phase cancellation may be occuring.
Jun 08, 2011 | Bass New David Eden D112xlt 1x12" Bass...
I have a Smith Corona word processor model XL 1900 but no instruction manual. Can you send me one by email?
I have a manual for the Smith Corona XL 1900 that I could scan and email to you if you give me your email address. my address is tricia_779@hotmail.com
Patty
Apr 04, 2010 | Smith Corona Wordsmith 100 Typewriter
Bass amp settings
For rock and slapping you are going to want to set the Bass and Treble controls high and the Mids low. For music such as Jazz you are going to want more mids so that your sound will be fatter. If there is a button marked "Mid-Scoop" you'll want that on when slapping.
Nov 08, 2007 | Audio Players & Recorders
23 people viewed this question
 Grubhead
Grubhead
