Question about Zenith Televison & Video
Lamp light won't go out after i put a new bulb in.how do you make the lamp indicator light go off
    President:
  • Zenith Master
  • 1,779 Answers
The procedure for re-setting the lamp timer should be in your owners manual.
Posted on Feb 03, 2010
2 Suggested Answers
  • 197 Answers
SOURCE: My PC50LC13 lost the picture at the same time the
did you putlamp door back,if so bad ballast
Posted on Jun 09, 2009
The right turn signal front is not working, All else works
Replace flasher, replace blown fuses.
remove bulb and put another new one in, test.
remove bulb check socket for corrosion - wipe with dielectric grease if corroded. reinsert bulb test.
very carefully check all wires connected to back of socket -
look for break or splits --R&R.
Check the signal feed wire with a probe from the back of the bulb socket - go back along wire towards signal light relay. R&R
You can find diagram on the web if you need one.
Feb 17, 2015 | 1999 Dodge Ram 2500 4WD
Fog lamps on 2004 Tahoe won't come on.
You need to check the bulbs.These are known to go out a lot.Also you can check that you have power to the lights with a test light.Sounds like a bulb or wiring problem.I have had a few of these that are broken off because they are so close to the ground.Depending on if your four wheeling or in snow country.Hope this helps.Good luck.
Feb 16, 2012 | Chevrolet Tahoe Cars & Trucks
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
I have a NEC VT700 projector. I replaced the bulb and housing because it would no longer turn on and the status light would blink every 2.5 seconds indicating the housing on the lamp had an issue. I...
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Jan 12, 2011 | NEC VT700 Projector
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Re sagem dlp 50 d4 tv
Hi,You get the lamp indicator when ballast(board that powers the lamp) is not able to light the bulb or bulb i not responding.Make sure everything is properly closed and have someone check if ballast is providing right voltage to the lamp.
Apr 07, 2010 | Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
I had the black & white dots on my 46" HLS4676S..Replaced the DMD chip..Plugged it in and the indicator lights then said I had a bad bulb...Installed a new bulb and the same thing happened. Turns...
Make sure you have firmly seated the new Lamp. The next step is to go to the rear of the set and put your ear next to the Lamp Door while turning "ON" the tv with your tv remote.
You should hear a short buzzing sound. That is the Ballast "Exciter" firing up to light the Lamp. If you do not hear this buzzing then you probably have a bad Ballast. Ballast part# is BP47-00037A
Jul 17, 2009 | Samsung HLS4676S Television
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
