RCA Hello. I am haveing a problem with the RCA 32v 434t Tv. When I turn My TV on my screen does not show,(or kick on) When i plug in my TV I here it receive power. I hit power (on ) The red light apears( on) but no (screen)? CAN YOU HELP! THANK YOU.
  • 54 Answers
Sir/maam i think thers a problem with its fly back,,,,,or its power supply going to the picture tube????kindly check it out thanksss and hope too help you!!
Posted on Feb 20, 2008
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
I have a 32" RCA
Hello
According to you, your RCA TV has went off while watching it. As there is no sound or picture at all, and the power kicks, the fault must be to its horizontal out section. The horizontal output section have LOT [Line Output Transformer] and related parts in it. Your TV must be chcked well to detect the actua fault. Normally, the LOT said above can be faulty, otherwise, the horizontal output transistor, the device that drive the LOT may also damaged. If this transistor gets leaky, the secondary main power DC supply will get a direct short, and the set will come on protection mode as we switch it ON. Here, according to you, this is happening. Just replace the horizontal output transistor first and see the effect. It is a three terminal component, screwed on to a metal heatsink, and can be located very near to the above said LOT.
After replacing it, switch On your TV, for a while, say 5 seconds or so, and if a whisiling sound is heard, and the replaced transistor over heats, the LOT said above is faulty, and should be replaced with same type and number. OK.
Apr 05, 2011 | RCA HD52W59 HDTV Projection Television
My tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
hello sir,
please sir solve my this problem.
my tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
Dec 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Tv not picture not sound
Is it varying the tuning voltage from 0v - 32v as it searches , if not then jungle/micro is faulty or check between tuner and micro/jungle
May 13, 2009 | Sharp 27C-240 27" TV
Connecting Laptop to LCD
VGA cable doesn't carry any audio: use your audio output from PC into TV audio Input (standard RCA).
You need to configure your Display Properties to manage TV screen to get an effective connection.
Either you have a generic Video Grafic Driver add on (I'm using Intel Graphic accelerator) on your display properties either you are using a specific (NVIDIA) driver for your video card.
To check go to CP/ Display, settings Tab and in advanced you should be able to check your choice (if you don't want to go to user manual.
You can also (in CP/ Display, Settings tab configure TV as a monitor and select your option accordingly: use screen resolution on screen # 2 not over native resolution of your VIZIO screen (1080 x 960?) and be sure to use all the parameters as TV can accept.
As soon as TV is configured as per resolution and refresh etc..
check the presentation function on your PC: it's normally a FN key showing a screen icon on key top (on my Acer travelmate is FN + F5) on aspire may be it's FN + F4.
This function key will circle between: PC mail screen -> External screen (as you configured on Display settings) -> both screen.
Jan 04, 2009 | Acer Aspire 3680 Laptop
52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
Televison & Video Logo
Top Televison & Video Experts
