I have a sceptre hdtv/x32bv/naga+ and the tv will turn on and its almost like its not getting enough power, the sceptre sign will come and go. The blue light flickers dose this mean that the power supply is fried? Now the cord that came with it is a 10A 125V cord but the input for the power cord on the inside of the tv says 15A 250V could the manufacturer have put the wrong cord in to be shipped? note: the tv has worked for almost 3 years and recently did this.
  • 148 Answers
I do not believe it it a faullty powerCORD....You have a faulty powerboard. The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..If this has helped you (or not) please rate, thank you!I have a sceptre hdtv/x32bv/naga+ and the tv will - cd17663.jpg
Posted on Feb 03, 2010
No picture or sound. when you turn it on it will flash "SCEPTRE" for a second and then go black. If i replace the capasitors will it be ok
You need to be able to test those capacitors and that takes a special meter. They can fail without any outward signs of failure.
Mar 13, 2016 | Sceptre X32BV-Naga 32 in. LCD TV
Sound but no picture
Try replacing the bulb, checking the power supply for a short circuit and examining the motherboard for burn marks or other signs that the screen's gone bad. Worst-case scenario, a new 32" TV costs a lot less than it did a few years ago, and Newegg.com often has good sales.
Aug 31, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
SCEPTRE X320BV i HAVE PICTURE ON YpbPR BUT NO SOUND/I HAVE SOUND IF IT'S TURNED ON AV
Connect the same input device to some other TV and check. Connect some other device with composite connections and check the TV.
Aug 06, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
I have a x32bv sceptre tv. everything works great but whn i plug a stereo into the audio out the audio buzzes.
What and where are you plugging into? Is sound normal on TV or when a DVD is played? This may narrow down what is happening.
May 25, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
Will not turn on
POWER SUPPLY IS BAD, YOU NEED TO REPLACE IT.. YOU CAN GET IT AT
TVPARTSANDMANUALS AT A GOOD PRIZE
Dec 18, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
I have a sceptreX32 light on tv turnes blue but the screen stays black
FAULTY POWER SUPPLY CAPACITORS OR INVERTER PANEL FAULTY ON BACK OF SCREEN
REPLACE AVERAGE COST £80+
Aug 25, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Nov 30, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre naga blue screen when tv on then turns blank, sound on
i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
Apr 18, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
I have a 32 inch sceptre naga. when i turn on a tv, the blue screen appears for less than a second and then goes blank. the sound is still on. what could be the problem
mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
Apr 17, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
Electro Med Services...
