Getting a alarm and error reading after paper jam
Printer will not work once paper jam was repaired. There is no paper in the machine and it is reading error and the alarm light is on.
  • 76 Answers
Wow theres a lot of information in that question. Thought long and hard about what you wanted to ask huh?
Like what model printer is it?
Posted on Feb 03, 2010
Printer is in alarm mode stating a paper jam when there isn't one?????
Even though u cant see a jam there there is exactly a jam inside
U believe it or not thats why paper jam
Look for the paper detection sensor below the carriage
use ur common sense
I cant say exactly it is detect sensor it may be some other sensor related to gear wheel set
but most of the cases paper jam occurs due to malfunction of paper detect sensor
If u find it use a thin tool to see it is working properly
otherwise give it to someone know how to repair & pay a reasonable price
thx
Sep 17, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Alarm blinking, I restrated printer, replaced ink jet and cleared printing queue but still error code comes up and won't work . error 6A00.
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 12, 2009 | Canon Pixma iP4500 InkJet Printer
Paper Jam Alarm - but cannot find any jammed paper?
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I was unsing my printer when it jammed. I cleared the paper however, the alarm light keeps coming on. I have tried turing the printer off, turning off the entire computer, turning the printer and computer...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 22, 2009 | Canon PIXMA® MP530 All-In-One Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper jam
open all door in your printer , front and back. , look for paper stuck inside and remove it. Sometimes small pieces of paper are difficult to be found.
If it is a Laser printer, you will also need to remove the toner and paper try and look for jammed papert underneat.
Once you done, restart the machine.
If you still have paper jam error try unplugging printer from power outlet for 5 minutes then restart.
If you still get error, then either there is paper inside or your printer may be faulty.
Regards
Mar 15, 2008 | Computers & Internet
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Feb 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
jasbo
jasbo
