Question about IBM Infoprint 1412 Laser Printer
The second light down from the top blue one is on all the time. Then when I go to print an envelope it will not feed and the light for jam comes on. Can never feed an envelope at all.
  • scholarsgold Feb 04, 2010
    Following your directions to check the photoconductor I get an OK on the printout. The other thing that I did was to open the envelop slide to accept a 8 1/2 X 11 sheet of paper and it took the paper in like it does a envelope then stopped. Then it would not print at all. Same with an envelope.
    The low toner light is on and the printout with the photoconductor indicator also said toner level low. I assume that this is the reason for the light.
    Scholar:
  • 94 Answers
The light indicator should be your toner and also the drum or photo-conductor replacement lamp. Have you replaced either recently? I also do not have the manual for this exact printer however, it to me is the same as a Lexmark machine I am familiar with - so I can get you a reset sequence in the morning. That will address the light indicator.
One thing I would like you to do while I'm getting you the reset sequence is to take out the toner and also the drum kit. The toner is seated in the drum kit and is removed separately. Inspect inside the printer for any remains of paper or an envelope as some jams in the drum area wrap themselves around the the drum roll and you may not have removed all in the past. Also while you have the drum in your hands - inspect it as well.
The envelope issue I do not believe is related at all to the indicator light, to clarify something for me please- when you attempt to insert a envelope into the aux feed - do you feel the rollers snug it into ready position? Can you print a 8.5 x 11 sheet through the aux tray? With that we can address that issue.
Keep me posted
Lou
Posted on Feb 04, 2010
  • 1 more comment
  • Lou H
    Lou H Feb 04, 2010
    Here is a procedure I would like you to do to reset the light:
    1-Power the printer on and get it to the Ready state (i.e. the light on the operator panel is on)
    2-With the printer on and in the Ready state, open the front cover
    3-Press and hold the Cancel button until all of the lights begin flashing up and down.
    4-Release the Cancel button and close the door. The photoconductor count should now be reset
    To confirm that the photoconductor page count has been reset, it is recommended that you print a
    menu settings page and check the photoconductor level. Do the following:
    1.With the printer at the Ready status, press the Continue button once. The Ready
    light will begin flashing and one or two pages will print out.
    2. Look for a section labeled Cartridge Information and locate the word Photoconductor
    under this heading.
    3. Confirm that the photoconductor level reading is either OK or close to 100%.
    4. If the reading is low, try printing 10 - 20 pages.
    5. Print the menu settings page(s) again.
    6. Confirm that the photoconductor level reading is OK or close to 100%.
    7. If the photoconductor reading is still low, there is a second, more detailed, procedure you
    can perform to reset the count.
    8. If the reading is still low after both procedures have been attempted, the printer may require service.
    Keep me posted if your still having issues with the PC kit reset. I can get you the more detailed procedure.
  • Lou H
    Lou H Feb 05, 2010
    ok good so the reset took care of the drum light.
    -now let me pull the one I have open to make it emulate the envelope or paper not pulling. It is starting to sound like a gear or cam is not engaging the pickup roller for the manual feed tray.
    Give me a few hours to get a solution for you.
  • Lou H
    Lou H Feb 07, 2010
    Hi - I still can not emulate teh problem - I've got one more item to try and will give you an update.
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Printing envelopes from gestetner 3502P
What size are the envelopes?
Envelopes have to be fed through the bypass. #10 envelopes are not recommended to run through the copier. There too small to feed through the fuser rollers and they will jam.
Sep 03, 2008 | Office Equipment & Supplies
IBM Infoprint 1412 Laser Printer Logo
130 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
