Question about Refrigerators
Icemaker not making ice.water to fill valve. power reads on the wires to the solenoid but the valve will not open.
    President:
  • 1,891 Answers
Only ans -- ( replace the valve ) mm
Posted on Feb 04, 2010
Why doesn't make my fridge not icecubes ?
There is a double solenoid water valve in the back of unit. This opens when the icemaker is ready to fill the tray with water. The solenoid valves control the water for drinking and the water for making ice. Most have push lock fittings some have compression fittings, so remove the solenoid valve wire connectors, the water lines and the solenoid water control valve and replace. Local appliance dealer should have one for about $60.00 or so. They make a universal solenoid water valve that fits most refrigerators.
May 29, 2014 | Daewoo Refrigerators
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
Replace ice maker still not making ice, it still dispenses water
Before suspecting the solenoid water valve, check the inlet tube, where the water enters the freezer. Sometimes this tube gets blocked with ice. From the back of the refrig, you can disconnect the water line where it goes into the back wall of the freezer and you should be able to blow air through it. (having the freezer door open while attempting this will prevent any back pressure build up) If you can not blow through it, it is plugged with ice. Melt the ice with a hair blower from the inside of the freezer. Ice blockage can result from water seepage past the water valve (generally requires replacement of the solenoid water valve) or the fill tube extention may be too long, resulting in the tube touching the end of the fill cup on the icemaker, which results in a build up of ice and blockage in the fill tube. (this only requires cutting the fill tube a bit shorter, so it does not touch the end of the icemaker's fill cup)
If you were able to blow through the tube, you have either a bad solenoid water valve, or the icemaker is not giving it power (generally only 6 seconds of power near the end of the cycle) which would mean a new icemaker, as replacement icemaker parts are not available.
Jun 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not makeing ice anymore
check the output power supply
Jul 07, 2009 | Refrigerators
Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Aug 27, 2008 | Refrigerators
Ice maker not making ice
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 19, 2008 | KitchenAid KSRP25FN Side by Side...
No water to the ice maker. No voltage to the inlet solenoid
icemakers work on a timed cycle and a timed fill. pressing the reset switch i would say solved your problem. I would switch the valves back to the way they were. The valve for the ice is smaller then the door water because the icemaker takes a small amount of water to fill. Good luck
Jul 21, 2007 | LG LRSC26910 Side by Side Refrigerator
Water not filling up the icemaker
it sounds as tho you do have solenoid prob.but it could also be an ice over sit at your water inlet tube that is situated near icemaker.
Jun 24, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
