Question about Samsung MT1066SS Convection/Microwave Oven
SAMSUNG MODEL # MT1066SB TURNS ON BY ITSELF LIKE IT IS IN A TIMER MODE
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
INTALLED A INTERMATIC TIMER AND EVERYTHING IS WORKING WITH THE EXPTION ON THE TIMER ITSELF. DO YOU HAVE ANY SUGESTIONS
1) First suggestion is for you to add a comment and say what model number Intermatic timer you are working with.
If this is a box timer, then model number shows on inside of door.
In any case, we are guessing at your problem without knowing model number.
2) If this is a box-type timer, main thing folks do wrong is reverse the line and load wires.
Line wires come from the breaker box, and Load wires go to the fan, light, motor.
Line wires have to be connected to the clock terminals or the dial will not rotate.
The clock terminals are usually visible as small white wires connect to two of the terminals. Again, this is dependent on model number.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Microwave Ovens
Our microwave/convecton turns itself off after about a minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Feb 05, 2009 | Sharp R-1870 Convection/Microwave Oven
Samsung Bake & Toast Microwave MT1066SB starts heating but shows
getting t-4 on clock display and random beeping<br /> cancelling and unplugging don't fix it<!-- from fixya rte -->
Jan 15, 2009 | Samsung MT1066SS Convection/Microwave Oven
GE Spacemaker Model JVM1860CD002 The oven comes on all by itself, starts in the express cook mode. This could be dangerous Rob
Beelow statmwent is refering to you appliance manual with also contains the wiring diagram. I woudl speculate that the clock/ timer wil turn out to be the problem since you said that you cannot set it.
Microwaves: Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel
http://www.geappliances.com/service_and_support/faqs/
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung microwave turns on by itself
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can order Samsung parts here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Samsung MT1066SS Convection/Microwave Oven Logo
85 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
