Question about Canon imageCLASS MF6550 All-In-One Laser Printer
I put new toner into machine and it will not copy. Put old toner in and sill wont copy. The paper comes out blank and no error message comes up. The scan function works fine. Will not print/copy.
  • 1,219 Answers
It is problem in laser shutter, call service, cant help you over net is complicated
Posted on Mar 06, 2010
It just won't make a copy. New
do you mean that copy comes out blank?
If yes, this is problem with laser shutter on laser unit.
Call service!
If the copy isn't blank, please give more details about problem...
Sep 14, 2011 | Canon imageCLASS MF6530 Copier
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
I replaced the cartridge and now it wont copy anything
If you mean blank copies then you either have installed a bad cartridge or perhaps you did not pull out the toner seal tape from the new cartridge before you installed it. If not then just remove the new cartridge and check one of the 2 ends of the cartridge for a small tape sticking out. Pull that out of the cartridge which will release the toner supply to the developer roller. Then re-install.
If you did this already then test for a bad cartridge by shaking the old toner cartridge back and forth a few times and put it back into the machine. It should work well enough to at least test for blank copies.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Canon PC1061 Copier
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
Copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
Sep 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Error messages but I can't find the errors
ona brand new machine you get a starter cartridge, you will need to put in a new cartridge
Feb 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
389 people viewed this question
old marine
old marine
