Question about Palm Treo 600 Handheld
Touch pad does not work. after running the touch screen alignment the screen says Please try again
  • smorris0517 Feb 04, 2010
    This did not work. I tried a hard reset and now the entire system is down.
    I have tried touching the pad in may different locations and cannot get it to accep alignment
    Palm Treo 600.
    The touchpad does not work.
    I have performed a hard reset and it is stuck in the "preferences" screen mode to align opposite corners and the center...after which the response is "please try again"
  • 2,069 Answers
I would recommed you perform a hard reset. please follow these steps:
To perform a “Hard Reset” on the Treo 600:
  • Unscrew the tip from your stylus
  • Locate the “RESET” hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, and then release the power button.
  • The screen will say “erase all data?”, tap the up arrow to answer yes
Regards
Posted on Feb 04, 2010
  • Muzahura Frank Feb 05, 2010
    I must tell you that what you are experiencing is common in that specific model. It just happens..just like that. At this point, i don't want you to think that your touch screen is dead but there is that possibility.
    Open your phone, do some cleaning because bad contact normally causes that. if still no response, then your phones touch screen digitizer is dead. consider replacing it.
    Regards
    Top Expert:
  • Palm Master
  • 76,682 Answers
Here are a couple of solutions, try them in order.
1.start making adjustments inward until the tap is registered and accepted. Once the phone allows you to pass this step, you can try to recalibrate the screen from the preferences.
2. Do a hard reset, to do this press the "up" button while pressing the "Reset" button
  • yadayada
    yadayada Feb 04, 2010
    I know this works is the software program is just locked up, lots of other users have tried it, so in your case the hardware has failed inside the device and you will need to have it repaired.
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key.
2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Feb 09, 2011 | Kyocera CS-2050 Black and White Copier
Touch pad is not working.
Go into Settings > Personal > Input
Down the bottom it should say "If stylus taps become inaccurate, align the touch screen."
Click on the word "align" that should be blue.
Jul 13, 2010 | O2 Xda IIs Pocket PC
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going...
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
Nov 28, 2009 | HTC Touch HD Smartphone
HTC Touch Diamond screen alignment
Hi
with the one i have, i have to take the battery out leave it for ten minutes and try again- if that doesnt work do it again -
get someone to phone you - try and tap the settings.
If this doesnt work - try the above again -
after 3 /4 times you will be able to get into settings and realign......
cheers
Sep 11, 2009 | HTC Touch Diamond Smartphone
Screen problem
hi..... this is the only way with the touch screens
  • If the touch pad is scratch or cracked , you can replace the touch screen(touch pad/Digitizer) only.
  • The touch screen have the protect film on it,please remove the protect film before you use the touch screen .
  • Before you buy this item please check your touch screen model and make sure it's same as the photo.
  • 100% brand new.
Jul 15, 2009 | O2 Xda Atom
Touch screen wont work
Have you tried removing the battery and waiting for a minute and replacing it in the phone.
The phone will reboot and possibly your screen will work again.
May 28, 2009 | Samsung Instinct Cell Phone
Touch pad - not double clicking for selection
Please run system restore but visit http:/www.hp.com go to drivers and download synaptic touch drivers again.
Good luck
May 19, 2009 | HP Compaq nc6000 Notebook
Display in landscape but the touch screen in portrait.
Tap the screen at target for some moment of time again & again until align screen don't go. After disappearing this time & date setting option will come.set these.after that windows installation will be started.It takes few minute.during installation don't press any key.after this phone will be started.
Nov 19, 2008 | i-mate JAMin Smartphone
Touch screen will not work
try to reboot it, there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Dec 12, 2007 | HP iPAQ RZ1710 Pocket PC
Palm Treo 600 Handheld Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
