Question about Yamaha YSP-800 System
NO POWER TO THE SPEAKER HAVE TRIED CHANGING THE FUSE IN THE PLUG. THE WEEK LEADING UP TO IT COMPLETELY BREAKING, IT KEPT TRIPPING OUT. I COULD TAKE THE PLUG OUT AND PUT IT BACK IN AND IT WOULD WORK AGAIN. IS IT SOMETHING SIMPLE OR AM I NEEDING TO TAKE IT FOR REPAIR. CAN YOU HELP PLEASE?
    Brigadier General:
  • 8,546 Answers
If something blows a line fuse twice there is something seriously wrong. Stop feeding it fuses. Take it in for a look-see.
Posted on Feb 04, 2010
Testimonial: "Great thanks for the help!"
  • David Dunn
    David Dunn Feb 26, 2010
    So what did it turn out to be?
I use my soup maker at least twice a week today it just kept tripping the electric. My husband. Hanged the fuse but still tripping and won’t work.
If the main RCD tripped the appliance has a fault causing the current to leak to ground. If the MCB tripped the appliance is consuming too much current or has a short circuit.
Only dismantling for inspection and testing will reveal the fault.
Mar 04, 2018 | Cars & Trucks
Plasma TV-power light does not come on
The fuses are inside the TV is you remove the back cover but even changing the fuse it might not work because it could have other failures in the other board assemblies.
How old is your plasma?
Jul 28, 2008 | LG 42PM3MV 42 in. PLASMA TV
Beko condensing dryer Model DRCS68. Hi, my dryer is tripping my electrics as soon as I turn the power on at the fuse spur. Any help on what else could be faulty that is tripping my electrics?
Are your fuses the proper size to run that dryer? A person I know put twenty amp fuses and could not understand why they kept blowing. I am not sure but I think it takes thirty amp fuses.. That's what we put in hers.
Are you sure its wired properly when you replaced the element.
Could be a short some place as well.
Oct 31, 2016 | Dryers
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
There is no stand-by light and it wont switch on, can anyone help? i have tried changing the fuse in the plug already
In that case the power source of the tv has completely failed. This is a very serious problem that should be handled by a pro, no serviceable parts inside.
Aug 18, 2010 | Televison & Video
Jimmy electrical burning.
The wire has rubbed somewhere and is shorted to ground. Replace the wire from the door switch to the light, replace the fuse with one of the correct amperage and it should work. Disconnect the battery while you are replacing the wire.
Jan 06, 2010 | 1999 GMC Jimmy
Intermittent breaker tripping
Have your installer check your wire connections first. These use a lot of power in turn the connections get hot leading to oxzidation leading to more heat...A vicous cycle. Other than that 40a sounds a little light depending on elect run and load on heater.
Aug 13, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Sony KV-35v35 no power
Bad Picture tube,and Flyback transfomer, shorted hori output.
Dec 12, 2008 | Sony KV-35V35 TV
Completely dead - Worked great for approx one week, now will not power up at all.
yes they really do not like being on the charger permenantly because it burns the cells out in the battery which is what I would say has happened here.
Maybe if you leave it sit for a week then plug the charger back in and see if it powers up you might be lucky
Oct 30, 2007 | Motorola Mobility HS850 Consumer Headset
Yamaha YSP-800 System Logo
410 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
