Question about Sony WEGA KE-42M1 42 in. HD-Ready Plasma Television
Sony wega 60" tv
Tv 2.5 years old. projection bulb and rear projector have already failed. thank god I had extended service policy through best (worst?) buy! tonight the tv went blank and the audio is gone. unable to obtain picure or audio. service man is coming tommorrow. should I cut my losses and ask best buy for another tv. sounds like this one is a lemon! advice?
  • 92 Answers
SOUNDS LIKE ANOTHER LAMP. WHICH MAY JUST BE BAD LUCK. PROJECTION LAMPS CAN GO OUT IN ONE DAY OR LAST TEN YEARS THERE SUPPOSE TO AVERAGE 4000 TO 6000 VEIWING HOURS AND THERE ARE MANY DIFFERENT FARIABLES THAT CAN AFECT IT. IM ASSUMING YOU HAVE A KDSR60XBR1 WHICH HAD A PROBLEM WITH THERE OPTICAL BLOCKS. I HAVE REPLACED MANY AND NEVER HAD A CALL BACK YET IN REGAURDS TO THAT BUT LAMPS ARE A DIFFERENT STORY. I WOULDNT WORRY IF I WAS YOU BUT IF THIS NEW LAMP GOES OUT SONNER THAN EXPECTED THEN I WOULD LOOK AT THE BALLAST IT IS WHAT POWERS THE LAMP
Posted on Feb 22, 2008
Sony Projection Wega TV
It was better to replace the light engine as a unit to such an old PTV.
Electro help
Jul 27, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Sony wega/60 inch would not turn on,is it the lamp or some thing else.
The tv LED light "LAMP" indicator flashes or lite up?Tv Projection lamp been inside this tv like about 2 years already,tv on and in used everyday like 4 or 5 hrs daily?Yes,than the tv projection lamp life are ended and require tv projection lamp replacement.
Jun 15, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Pink line at top after bulb replacement
If you have a pink shadow (meaning you can still see the picture in it) the light engine (projector part of tv) where the bulb goes is failing. you have to replace projector. contact Sony quick as it might still be under extended warranty. They had class action lawsuit and extended warranty on many models becuase of this problem but they expire soon. Good luck.
Apr 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
What is the difference between a light engine and optical block?
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
Nov 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue haze from lower left slowly starting to consume the screen
The blue LCD panel in the light engine is going bad. The only fix is to replace the light engine. This is an extremely expensive repair. However, Sony has extended the warranty on the light engine only on many of these models. Find a local Sony authorized service center and give them your model and serial number to see if yours qualifies for the warranty.
Jun 04, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Bottom right side of screen (about 4 inches high) has blue tint
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the "Optic Block", ($1300. -not incl labor), that was replaced to fix the problem. That part contains all new LCDs, & multiple Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended).
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have automatic FACTORY extended warranties (up to 10 years), because of some known problems with the blue LCD panels. You might want to contact a SONY office & see if your set is covered.
ALSO - The tech checked my Service Codes & showed me the TV had been running for 10051 hours in about 4 years - on the Original bulb! He was quite surprised because he said the bulbs usually last about 5000 - 7000 hours. He also said it's good to replace them BEFORE they go bad, because they can sometimes burn out the amplifier that powers the bulb, (which is a seperate piece that attaches to the outside of the Optic Block). My TV is like new now.
Dec 25, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
OUr Sony Grand Wega KDF-60XS955 has a blue corner
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the $1300. (not incl labor), Optic Block that was replaced to fix the problem. That part contains all new LCDs, & Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended)
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have FACTORY extended warranties because of some known problems with the blue LCD panels.
Dec 23, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony WEGA KE-42M1 42 in. HD-Ready Plasma Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
