Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Replaced my boost pump and now eveb before I turn on bust pump water runs out around metal seal and seal bracket. I have removed and reseated seal and applied sealant lub. any ideas
    President:
  • 2,030 Answers
You either have a bad seal or bad connector..make sure you check them both very well....and if you didnt use a new seal, the old seals are pron to leak when re used.
Posted on Feb 03, 2010
I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
2 possible problems:
1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
Mar 24, 2014 | Samsung WA456DRHDWR 4.5 cu. ft....
Water pump 2000 3.0 liter dodge caravan
For The 3.0 Motor. (3.3 Way down the line.)
Drain cooling system.
Remove timing belt. Refer to Engine for procedure.
Remove water pump mounting bolts.
Separate pump from water inlet pipe and remove water pump.
Timing Belt Removal
Raise vehicle and remove accessory drive belt splash shield (Fig. 66).
Remove accessory drive belts.
Remove crankshaft pulley and damper (Fig. 68).
Support engine and remove right side engine mount.
Remove engine support bracket (Fig. 67).
Remove timing belt covers (Fig. 67).
Mark belt running direction for installation (Fig. 69).
Loosen timing belt tensioner bolt (Fig. 71) and remove timing belt.
Remove crankshaft sprocket flange shield (Fig. 68). CAMSHAFT SPROCKETS To remove camshaft sprockets
Hold camshaft sprocket with Spanner Tool MB-990775. Loosen and remove bolt and washer (Fig. 70).
Remove camshaft sprocket from camshaft. To install camshaft sprockets:
Place camshaft sprocket on camshaft.
Install bolt and washer to camshaft. Using Spanner Tool MB-990775, hold camshaft sprocket and torque bolt to 95 Nm (70 ft. lbs.) (Fig. 70). TIMING BELT TENSIONER
Install timing belt tensioner and tensioner spring.
Hook spring upper end to water pump pin and lower end to tensioner bracket with hook out (Fig. 71).
Turn timing belt tensioner counterclockwise full travel in adjustment slot and tighten bolt to temporarily hold this position (Fig. 72).
INSTALLATION
Install timing belt on crankshaft sprocket and keep belt tight on tension side (Fig. 69). Install belt on the front (radiator side) camshaft sprocket. Install belt on the water pump pulley, rear camshaft sprocket and finally on the timing belt tensioner.
Rotate the front camshaft sprocket in opposite direction to take up belt slack. Check that all timing marks are aligned (Fig. 69).
Install crankshaft sprocket flange (Fig. 68).
Loosen tensioner bolt and allow spring to tension timing belt.
Turn crankshaft two full turns in clockwise direction. Turn smoothly and in clockwise direction ONLY.
Align the timing marks on the sprockets and tighten the timing belt tensioner locking bolt to 28 Nm (250 in. lbs.) torque.
Install timing belt covers.
Install engine support bracket.
Install right side engine mount.
Install crankshaft damper and pulleys (Fig. 68). Tighten damper center bolt to 135 Nm (100 ft. lbs.) .
Install accessory drive belts.
Install accessory drive belt splash shield (Fig. 66).
Be sure to also replace all the cam and crank seals why you are there. Might as well put a belt on too.
FOR THE 3.3 OR 3.8 MOTORS.
Drain Cooling System.
Remove accessory drive belt.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws. Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface
Installation
Install new O-ring into groove.
Install water pump to chain case cover. Tighten screws to 12 Nm (105 inch lbs.) .
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 Nm (250 inch lbs.) .
Install accessory drive belt.
Install right front lower fender shield.
Refill Cooling System.
FOR THE 2.4 MOTOR
Disconnect negative cable from battery.
Raise vehicle on a hoist. Remove right inner splash shield.
Support engine from the bottom and remove right engine mount.
Remove right engine mount bracket.
Remove timing belt idler pulley.
Hold camshaft sprocket with Special tool C-4687 and adaptor C-4687-1 while removing bolt. Remove both cam sprockets.
Remove rear timing belt cover.
Install new O-ring gasket in water pump body O-ring groove. CAUTION: Make sure O-ring is properly seated in water pump groove before tightening screws. An improperly located O-ring may cause damage to the O-ring and cause a coolant leak.
Assemble pump body to block and tighten screws to 12 Nm (105 inch lbs.) . Pressurize cooling system to 15 psi with pressure tester and check water pump shaft seal and O-ring for leaks.
Install rear timing belt cover.
Install camshaft sprockets and torque bolts to 101 Nm (75 ft. lbs.) .
Install timing belt idler pulley and torque mounting bolt to 61 Nm (45 ft. lbs.) .
Install timing belt. Refer to Engine for procedure.
Install right engine mount bracket and engine mount. Refer to Engine for procedure.
Fill cooling system.
Lower vehicle and connect battery cable.
Mar 29, 2012 | Cars & Trucks
I have a 2hp sprinkler pump that I am having trouble priming. I have 2 check valves on in the water by the intake and the other by the pump. It has take a few hours to get the water to the pump but still...
1. You only should have one check valve; the one in the water is best, remove the other if you can.
2. Make sure there are no leaks in any of the piping between the water and the pump inlet.
3. Take the pump apart, thoroughly clean the new seal, the two halves of the pump that go under the metal band, the inside of the metal band.
4. Lubricate the new seal, the outer sides of the pump halves where the metal band squeezes together, the inside of the metal band where it contacts the halves and even the screw on the tightening device using petroleum jelly (Vaseline) or equal. Make sure the pump literature does not recommend against whatever you use.
5. Reassemble.
6. Fill the pump with water, open the discharge on top of the pump if possible and prime.
Normally, a pump, even with a long run will prime in 5 minutes or less.
Write back.
Your FixYa Texpert,
Gary
Aug 22, 2011 | Flotec Corrosion Resistant Convertible Jet...
How do you replace water pump?
Assuming this is a 460 Ford Big Block:
REMOVAL
-Drain cooling system.
-Remove drive belts.
-Remove bolts attaching fan shroud to radiator.
-Remove fan blade from fan clutch and remove fan shroud.
-Remove fan clutch and water pump pulley from water pump.
-Remove four bolts and one nut attaching A/C compressor mounting bracket to cylinder head and water pump. Do not remove A/C compressor or power steering pump from A/C compressor mounting bracket.
-Pull A/C compressor mounting bracket forward to remove from stud on water pump.
-Remove bolt attaching generator adjusting arm to water pump. Remove four bolts attaching generator mounting bracket to cylinder head, cylinder block and water pump.
-Remove remaining water pump attaching bolts and remove water pump from engine front cover.
-Remove water pump cover from water pump. Discard water pump housing gasket and water pump cover gasket.
INSTALLATION
-Remove any gasket material from water pump cylinder front cover and separator plate mating surfaces.
-Position new water pump housing gasket and water pump cover gasket coated on both sides with Perfect Seal Sealing Compound B5A-19554-A or equivalent water-resistant sealer meeting Ford specification ESE-M4G115-A.
-Position water pump and water pump cover onto engine front cover. Install bolts and tighten to16-24 Nm (12-18 ft. lbs.).
-Install generator mounting bracket to cylinder head, cylinder block and water pump with four attaching bolts. Install generator adjusting arm to water pump with one attaching bolt. Tighten 7/16-inch bolts to 54-71 Nm (40-53 ft. lbs.) and 3/8-inch bolts to 41-54 Nm (30-40 ft. lbs.).
-Position A/C compressor mounting bracket over water pump stud and secure to cylinder head with four bolts tightened to 54-71 Nm (40-53 ft. lbs.) and secure nut to water pump to 41-54 Nm (30-40 ft. lbs.).
-Install water pump pulley and fan clutch to water pump hub with four bolts. Install fan blade to fan clutch with four bolts. Tighten water pump pulley, fan clutch hub bolts, and fan-to-fan clutch hub bolts to 16-24 Nm (12-18 ft. lbs.). Install fan shroud.
-Install drive belts.
-Fill and bleed the cooling system.
-Start the engine and check for leaks
Jan 10, 2011 | 1997 Ford F350 Crew Cab
We set up our pool filled it and turned on pump for 24 hours then turned on the saltwater system. Immediately tested the copper level with the strip it said 0 so we put system into boost mode and now this...
Metal in the water. When you fill your pool, immediately treat as if you had metal, according to package insructions ... (pump running generally speaking).
I dont know why, it seems metal is sometimes hard to detect ... treat the water anyway. In my area, the stuff costs less than $20.00 which is way cheaper than removing the metal AFTER you find it!
Jul 10, 2010 | Intex Automatic Salt Water System for ...
How do i replace a water pump on a 1993 geo
1 disconnect battery ground cable
2 drain cooling system
3 on models with a/c, proceed as follows:
a discharge a/c system
b loosen upper and lower compressor bolts and remove compressor drive belt
c remove a/c line from top of radiator shroud
4 remove water pump drive belt
5 remove reservoir tank from radiator bracket
6 remove radiator shroud and fan/clutch from vehicle
7 remove waterpump pulley from waterpump
8 remove timing tensioner and timing belt
9 remove dipstick tube
10 remove alternator mounting bracket at water pump
11 remove water pump mounting bolts and water pump
12 reverse procedure to install, using new gasket and rubber seal
Feb 18, 2010 | 1993 Geo Tracker
Water pump replacment precedure on 2001 jag stype 3.0
Hello
To replace water pump : Raise the car
1- Drain cooling system. 2- Remove drive belt tensioner clip (if there is one) 3- Remove accessory drivebelt * Rotate the belt tensioner counter clock wise , 3/8 inch square drive bar should do it
* Remove accessory drive belt
4- Lower the car 5- Remove the upper shield. 6- Remove the throttle body. 7- Detch the coolant hose from housing assembly. 8- Remove the upper radiator mounting bracket 9- Detach the hose assembly from the water pump and lower hose. 10- Remove the hose assembly * Detach the hose clips
11- Remove intake manifold support bracket * Detach wiring harness
* Remove intake manifold support bracket
12- Detach coolant hose from water pump 13- Remove coolant hose from the water pump to lower housing. 14- Remove water pump
Installation :
in reverse order and make sure to use new gaskets and seals
Jul 07, 2009 | 2001 Jaguar S-Type
Water pump removal (cant get power steering pump out)
To access and remove the waterpump, the powersteer bracket has to be removed completely. To do this, the rear camshaft drive pulley must be removed (need a tool to hold pulley, bolt tight) and then the thin sheetmetal shield behind the pulley. This allows access to the lower powersteer bracket bolts.
Removal of the engine mount is also required to perform timing belt replacement. It also helps to increase your access room too.
I would recommend you replace the waterpump why you are there as they have a tendancy to fail at around 140000 km's.
May 23, 2009 | 1994 Mitsubishi Diamante
1995 Plymoth Voyager
The water pump bolts directly to the engine block, using a gasket for pump-to-block sealing, The water pump is driven by the timing belt and is serviced as a unit.Disconnect battery ground cable.Remove crankshaft drive pulleys and torsional damper,and Right Engine Mount & Bracket.Place a jack under engine to support and slightly raise engine, then remove engine mount bracket.
Remove timing belt cover, then mark belt running direction for reinstallation.
Loosen timing belt tensioner, then remove belt and crankshaft sprocket flange shield.
Separate water pump from water inlet pipe, then remove water pump.
Reverse procedure to install, noting the following:
Use a new O-ring on water inlet pipe.
Torque water pump mounting bolts to 27 Nm (20 ft. lbs.).
Dec 24, 2008 | 1995 Plymouth Voyager
How Do i replace Water Pump on 98 Chevy Metro
  1. Remove the negative battery cable.
  2. Drain the engine cooling system.
  3. Remove the air cleaner assembly.
  4. Remove the A/C compressor suction pipe bracket (if equipped).
  5. Loosen four water pump pulley bolts. Do not remove the bolts.
  6. Raise the vehicle. Support the vehicle. Remove the right lower splash shield.
  7. Remove the right lower splash shield.
  8. Remove the A/C compressor drive belt (if so equipped) by releasing the tensioner pulley and removing the belt from the crankshaft and compressor pulleys.
  9. Loosen the generator adjusting bolt (1), pivot the generator and remove the water pump/generator drive belt.
  10. Remove the crankshaft pulley.
  11. Remove the water pump pulley (four bolts).
  12. Remove the timing belt.
  13. Remove the oil level indicator (dipstick) guide tube.
  14. Remove the upper generator adjusting bracket from the water pump (one bolt).
    1. Remove the rubber seals from the water pump.
    2. Remove the water pump mounting bolts and nuts.
    3. Remove the water pump and gasket from the vehicle.
    4. Clean the water pump and the gasket mating surfaces.
    5. Install the water pump.
    6. Secure the water pump with mounting nuts and bolts. Tighten Tighten the water pump mounting nuts and bolts to 13 Nm (115 ft. lbs.).
    7. Install new rubber seals (1) to the water pump (2).
    8. Install the upper generator adjusting bracket to the water pump (one bolt).
        • Tighten the upper generator mounting bracket bolt to 23 Nm (17 ft. lbs.).
      1. Install the oil level indicator (dipstick) guide tube.
      2. Install the timing belt.
      3. Install the water pump pulley.
      4. Finger-tighten the four bolts.
      5. Install the crankshaft pulley.
      6. Install the water pump/generator drive belt to the crankshaft, water pump and generator pulleys.
Nov 20, 2008 | 1998 Chevrolet Metro
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
97 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
