Question about Quantum Fireball Plus LM 30 GB ATA-66 Hard Drive
The hard drive is connected and running as an external hard drive but my desktop computer does not recognize it (in "My Comouter"). No icon for it appears.
    President:
  • 2,600 Answers
Reboot the computer and change the usb socket you are using, make sure you have internet access so if needed the operating system can load a driver if it needs. There is also the possibility that the driver has interface issues and may not work with an adapter attached to it.
Posted on Feb 03, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
My hard drive is not being recognize
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 06, 2013 | Computers & Internet
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
A blue and red flashing light and won't connect to computer
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
Blinking light flashes continually. The pc can not access the eternal hard drive. I have re-started the pc several times and the pc will not recognize the external hard drive. The WD External Hard Drive...
try to connect the usb port properly maybe there is a loose contact. and try to remove all the gadgets connected in the computer... only connect the external HDD
Oct 30, 2010 | Western Digital External USB 2.0 80 GB...
WD Elements external hard drive not recognized/can't be found
ur vista version has a problem with usb portable devices so either u have to upgrade ur vista to the latest on or install windows 7 or down grade ur laptop and install windows xp
Jul 27, 2009 | Computers & Internet
Computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Jul 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
MAC Computer won't recognize Maxtor External Hard Drive
that disk is not detected by windows due to power failure to your hard drive. check power of your drive.
May 20, 2009 | Western Digital My Book Essential Edition...
LACIE DRIVE NOT READING
try going to the manufacturer web site for the make of the hard drive
find a download for that model and select mac as the operating system\
download and run
Dec 02, 2017 | Computers & Internet
Quantum Fireball Plus LM 30 GB ATA-66 Hard Drive Logo
103 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
