Question about Samsung SyncMaster 912N 19" Flat Panel LCD Monitor
OOPS! How to invert screen image )get it back where it belongs)
My PC locked up while I was web surfing. I lost my temper and banged on the keyboard keys quiet hard, several times, mostly on the right side numeric keys.
The image on the monitor screen turned upside down and now I have to turn the monitor 180 degrees to read the screen. "System Restore" will not fix the problem. My Samsung manual does not cover that sort of stupidity.
I think I hit the wrong combination of keys and now don't know how to undo the BOO BOO.
HELP please. Thanks.
Thanks. I just reloaded the driver and got things back to normal. That is, all except this bad temper of mine.
Posted on Feb 21, 2008
    Scholar:
  • 198 Answers
Just take it to the showroom where u got it from. this problem can be fixed without any big problems
Posted on Feb 20, 2008
My numeral key are not working[123456789 right side of key bord]
Step 1:
On some laptops it may be difficult to locate and activate the "Num Lock" key. Depending on the laptop, it may be hidden as a function where you have to press two keys. Most of the time, a laptop keyboard is just like a full desktop computer keyboard and it has a "Num Lock" key on it. Most people do not realize the "Num Lock" key is on their laptop keyboard because it barely serves a purpose without a full numeric keypad.
Press the "Num Lock" key on the laptop at the top, right of the keyboard. Press the "Num Lock" key and the "Fn" key simultaneously if the above does not work. Press "Fn" and "F11" simultaneously on the keyboard to activate the "Num Lock" function. Some laptops, like Toshiba, do have a "Num Lock" key. The shortcut for G3 Mac laptops it is "F5," and on G4 Mac laptops it is "F6."
Feb 07, 2013 | Computers & Internet
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
Dell inspiron 2200 laptop - what are the 4 lights on top right of keyboard for? the first one is constantly blinking and the others are never lit up
Hi those are your keyboard and status lights
Looking at your laptop from the front the first light on your Right hand side is your scroll lock light and is only on when you press the scroll lock button (the symbol shows a lock with a little down arrow)
The light to the left hand side of that light is your caps lock light and again only turns on when you press the caps lock key (The symbol shows a lock with a A in it)
The light to the left hand side of that is your numeric keypad light (Symbol has a lock with a 9 in it), this comes on when you press the num lock key on your keybaord
Finally the last key is your hard drive light (like a cylinder), this will be flashing most of the time as you use your PC as it is constantly reading and writing data
Regards
Shauqat
Jun 10, 2010 | Dell Inspiron 2200 Notebook
Keying numbers instead of letters whun num lock on
Check 2nd Function keys. The problem you describe is normally a Fn +numlock keystroke on most systems
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Numerical lock problem
Hi there
If its a wired Keyboard you are using, you have to set it in the system bios F2. Esc or Del on startup.
Good luck and thanks for using Fixya!!
Feb 12, 2009 | Dell 0Y3740 Keyboard
Right side of keyboard locked up
Try hitting the fn key which means Function some laptops you hit twice and it will keep it on constant and won't allow you to use your letter keys
Happy Holiday
Dec 24, 2008 | IBM ThinkPad T41 Notebook
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Logo
139 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
