Question about Brother MFC 240C All-In-One InkJet Printer
Scanner belt slipping
When I plug in the printer, the scanner light-bar does it's little self-test thing, and it goes to the right a few inches, then back to its home. But the belt gears keep spinning, creating a grinding noise while the gears slip on the belt. This goes on for way too long, then the printer returns an error. It seems that it doesn't recognize when the scanner has returned to it's home position. Is this something that can be fixed with a new part, or is the circuit board shot?
  • planetmark Feb 20, 2008
    The error message showing on the LCD says the following: "See Troubleshooting and routine maintenance chapter in User's Guide." Then it says "Scan Unable AP".
    I've already checked the flat cable. It's plugged in. I unplugged it and re-plugged it to be sure. That doesn't affect the problem.
I have the same issue: scanner does not know when the light-bar has reached home position so the motor continues to turn the cog which slips under the belt causing a loud rattling until it decides (incorrectly) that something is blocking the "light-bar" from returning home and it stops and says error "scan unable". I've taken it all apart and I can't even figure out how the light bar is supposed to know when it has returned to the beginning (home) position.... anybody?
Posted on Sep 06, 2011
  • do00od Sep 06, 2011
    oh come on 4 years and nobody knows how to fix this?
  • 832 Answers
Check flatcable connection to main circuit board:
Open cover and release the "Z" cover (right side) which hides the flatcable. Simply stick the cable to mainboard.
Posted on Feb 20, 2008
  • Mix-it-up
    Mix-it-up Feb 20, 2008
    Check the silver edges of the cable carefully which used to be the plug-in side to mainboard. Are they OK or is there a broken line in it? If yes, try to fix it by cutting off a piece of the cable, deisolate it anf form it to a new plug in.
    If connection is good you might have to open the scanner and readjust the cable and lighting tube.
Have a Lexmark X5650 printer/scanner that won't scan at present. Trying to scan my work (comic book artist) to a memory chip then into photoshop on the laptop for tweaks before turning them in and the...
ok. if its making a grinding noise its the belt slipping. you may not have the print cartridges installed properly. kit could also be the scanner belt that may be slipping. Basically if its not the print cartridges then the scanner is stuffed. Unless you are handy and are prepared to pull thing apart to get to the scanner belt I'd say it has gone to god.
Jan 17, 2011 | Lexmark Office Equipment & Supplies
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP 2210 scanner self test problems
If the glass of your scanner is too close to the scanner array it can jam. The cure for this problem is to open the case and put some narrow strips paper under the glass. If under Guarantee take it back.
Doubt if you can bypass the self test.
Mar 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2110 copy problem stuck warming up & scanner bar get stuck
The scanner carret belt might be too loose, so the printer cannot pass through the self-test. Try tightening it a little bit. Also you have to either repair the nobs or solder it.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Scanner Bar won't move
Try first unplugging the power cables for ten minutes, also restart the computer.
Check if this model has a lock button to secure the scan, this is usually indicated with a lockpad, and is a small tab, if there is one is indicated on the manual.
Plug it back and do the following:
This sounds like an hardware fault, since the scanner starts, but just in case , ensure the drivers are working fine by reinstalling software from scanner disk. And eventually test the scanner on a different computer, for example a laptop. Use the scanner CD to do intall scanner drivers before connecting the scanner.
If it still does not work.
Check if the scanner lamp goes on when you send a scan, if not the lamp must be replaced.
The most likely is that the traction belt had slipped out, one of the mechanichs are stuck, or the motor is faulty.
In this case the scanner must be taken apart, the job can be done at any local repair shop.
Dec 14, 2008 | Sharp AL 1631 Copier
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
Clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Initializing self test scanner
http://www.fixyourownprinter.com/forums/inkjet/19182
Nov 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
297 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
