Question about Jenn-Air Pro-Style JGCP636ADP Gas Cooktop
Gas smell from one burner
We just installed a new jenn air cooktop and when it is turned off I smell the slightest hint of natural gas down around the front left burner. I turned off the gas supply line to the unit but am wondering if this may simply be a shut off valve adjustment or if it will need a major repair- Anhy ideas?
  • 80 Answers
Get guys back, leak test it. you can use a soapy solution like dishliquid mixed med think and brush it on connections and look for samll bubbles, make sure you have gas on to do this!!
Posted on Feb 05, 2010
Suddenly my Jenn air gas cooktop ignitors (all of them) do not click and spark, the model is CVGX2423B. I suspect it might be spark module fails, is that right?
It sounds like you need a new spark module which controls all of the burners. It is part number W10475147. It costs around $115.00!
Sep 01, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
We just bought an older house with a jenn air cook top but the pilots are out. How do we light them?
First, you need to look below the cooktop to find the gasline. There is supposed to be a shutoff valve on this gasline. Turn the handle so it is parallel with the gasline (perpendicular is closed) to open it. Before lighting anything, smell around high and low around the cooktop and make sure you do not smell any gas. You can also spray soapy water on all the gasline fittings to detect leaks by looking for bubbles that form. If all is safe, using a long butane lighter, light the pilots for the cooktop. There should be 1 pilot for every 2 burners. You will probably have to remove the grates and metal spill covers to light the pilots. The pilot should be approx 3/8" tall or less. Test each burner individually to make sure they light off the pilot. If they do not, you may need to clean the vertical holes on the side of the burner (where the lighting tunnel connects) by poking them clean with a needle. If the horizontal burner holes are clogged, clean them as well. If there is also a built-in wall gas oven, be sure to light that pilot on that as well. Good luck. Douglas
Sep 28, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Burner clicks a long time before igniting you can smell the gas
Not sure about what part 1 is about. #2 indicates a failing ignitor gap or a bad gas mix. Get professional assistance.
Jun 13, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
JED8430 Fan Burning
great love it when people do this just commom sense most of the time
Dec 28, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air Pro-Style JGCP636ADP Gas Cooktop Logo
217 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
