Question about Car Audio & Video
Amplifier plays for 2-3 seconds and then completely shuts off, but LED indicatoes lit. What is the most likely component that heats up?? 50 watt amp. Thanks
  • 1,068 Answers
The transistor that mount to the amps body (heat sink) inside. most common issue with these.
Posted on Feb 04, 2010
Pyle amplifier class c
Sounds like the motor or it's drive circuit, is pulling all the power so the amp shuts down. You need to check the motor or it's power supply section to see if it's faulty.
Apr 03, 2013 | Audio Players & Recorders
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Ok, i love the tones on this amp, but for some reason, i start to play, not even on at a high volume, just like at a nice level, ill play it for like 5-8 mins and it will shut off, like the power is still...
This is a tiny amp good for practice at low volume levels. You are likely overdriving it and the power amp chip goes into thermal protect. If you volume level is much louder than a small boom box, you are driving it too hard. Best to get a bigger amp.
Jan 26, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
The protect led has turned on and will not allow the amp to work. I've tried re-wiring the whole unit, changed the fuse to a high wattage, I've given it time to cool off in case it was over heating. Ive...
mosfet have a built in shut off incase of a blown resistor, if the resistor blows,it will shut down the amp, the resistors job is to inhibit power to prevent overheating, you will have to check the OHMS of each resistor to find out which one has gone......hope this was helpfull
Sep 15, 2009 | Pyramid PB1000 MOSFET Bridgeable Amplifier...
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
