Question about Dell 3200MP Multimedia Projector
Dell 3200mp lamp
I replaced the lamp in my Dell 3200mp when the orange lamp indicator came on and the lamp would not light. After replacing the lamp with a new one I still have the same problem.
  • buch61 Feb 20, 2008
    The bulb is the same and I have done a cold boot a couple times. Is there a way to test the bulbs or test the connection plug?
  • 871 Answers
Are both of the lamps the same? have you installed it correctly in the socket. you might need to do a cold start for your projector. unlpugg it and try to wait for 5 minutes before plugging it again and turning it on. one your projector detected that a new lamp is intalled, it should work fine now. but if its still not working, you might want to try and replace the new lamp again. sometimes this happens.
hope this helps.
Posted on Feb 20, 2008
Dell 3200MP DLP Projector: displays OK, but with vibrations soon as power button is pressed ON. found cause; rotating see thru thin plastic disk has a quarter of the disk broken off, thereby causing...
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Jul 04, 2011 | Dell 3200MP Multimedia Projector
Replaced the lamp in my Dell 3200mp projector when the lamp indicator came on. After replacing the lamp indicator is off , but the lamp will not even attempt to light. Anything else I can check?
did the old lamp fail? Or did the lamp light just come on?
Firstly I would disconnect the mains and carefully put the old lamp back in. Test the projector. Then put the new one back in and test.
There can be problems with lamps not being seated correctly, and/or the lamp cover not being fully closed.
Post back for more help if required.
Dec 29, 2010 | Dell 3200MP Multimedia Projector
My projector not working error is TAMP WARNING LIGHT BILINKING
Replace the lamp
Check online at several places because some are rip-offs
Nov 03, 2010 | Dell 3200MP Multimedia Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Dell 3200mp
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @ussmillerco@yahoo.com and let me know. Good luck thx sean
Nov 21, 2008 | Dell 3200MP Multimedia Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
Dell 3200 Projector
Hi Tara
This normally indicates that the lamp will need replacement.
The Ibook and this Projector are compatible as long as you run a Microsoft operating system i.e. Windows 98' and higher.
When replacing the lamp , you can just as well clean out the Projector - this is quite important as it prolongs the life of your lamp.
May 18, 2008 | Dell 3200MP Multimedia Projector
Dell 3200mp
Hi Lagnitta
Take out the lamp and check for any irregularities like discolouration and marks.
This is unfortunately dammage to the lamp and the lamp will need replacement.
Thanks for using Fixya.
Apr 27, 2008 | Dell 3200MP Multimedia Projector
Dell 3200mp lamp not working
Dude! You just saved me 250.00..It worked...I could kiss you!! ...HA! HA!...:)
Feb 19, 2008 | Dell 3200MP Multimedia Projector
Pictue shakes
Sounds like the lamp needs to be replaced. Does the "lamp" light on the top turn solid orange when it turns itself off? That's an indication that the unit has sensed that the lamp is no longer "good".
Apr 27, 2007 | Dell 3200MP Multimedia Projector
Dell 3200MP Multimedia Projector Logo
288 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
