Question about Yamaha P2500S Amplifier
Protection of yamaha pc 2002
I have Yamaha power amp PC 2002 and one side stays under protection 10m more minits than the other side.After that amp works very well.Any idea or schematic for this model and also for model 2100 which gives me another problem.All regards
    Novelist:
  • 236 Answers
Time delay... i dont know...seems unusual. the protection system of all yamaha PA and A/V is driven at teh same time not discrete so i dont understand why 1will be active earlier and the other delayed. in any case, a delay in relay activation is unstable center violtage or you are having an abnormal output stage, it is prducing more than 0.1 volts DC. this is primarily caused by unbalanced biased input initial stage of the main amp, voltage stability is not accurate. Or grounding getting poor.
redrivera
Posted on Mar 19, 2008
  • 54 Answers
Protect delay is in the relay and not adjustable as to delay time.
I would not worry unless no sound then may have to replace relay.
GOOD LUCK
BIG RED
Posted on Mar 04, 2008
My RX-V2095 Yamaha receiver won't power up.
Wont power up, or stuck in "protect mode"? Unplug the unit & let it sit for a couple hours, then plug back in & listen for a "click" a turn (power supply relay energizing.) If no lights & no click, the first place to check is the mains fuse. If the unit is under warranty - take to an authorized facility & they will take care of it for you.
Oct 20, 2014 | Yamaha Rx-v2095 7ch Flagship Home Theater...
How to fix problems internally on a yamaha p3200 power amp when the protection stays on from cold power up
First check all speaker wiring to make certain there's no shorts.
Protection system come on if there's an overload. These are caused by shorts. If the speakers and wires are good then the only other cause is the main amp, possibly a transistor, has shorted.
Jun 22, 2012 | Yamaha Audio Players & Recorders
Yamaha p4500 in protection mode
The manual says the heat sink is too hot or an unacceptable DC voltage was sensed going out.
http://www.retrevo.com/support/Yamaha-P4500-Amps-manual/id/962bh144/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Oct 07, 2011 | Yamaha P4500 Power Amplifier 2-Channel
After power outage, the units internal saftey switch has activated. How do i reset the reciever? It's a Yamaha RX A1000
If the protection circuitry has been activated 3 times consecutively you may have to contact Yamaha as it says in the Troubleshooting section of the manual.
http://usa.yamaha.com/products/audio-visual/aventage/rx-a1000_black__u/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 27, 2011 | Yamaha RXA1000 Receiver
YAMAHA RX-V795 WILL NOT STAY ON WHEN POWER BUTTON IS HIT. JU...
Jul 20, 2011 | Yamaha RX-V795 Receiver
Yamaha DSP-AX1 ,. When turning on it only stays on about 4-5 sec. then shut off. Bob
Is this new equipment or a new problem on working equipment?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-DSP-AX1-Amps-manual/id/319bh827/t/2/
See Troubleshooting Page 79
Impedance Selector in between settings
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Apr 07, 2011 | Yamaha DSP-AX1 10-Channel Amplifier
My Yamaha DSP A1 after switching ON goes OF itself after 2-3 seconds! Please give me advice what to do Thanks, Alex
http://www.retrevo.com/support/Yamaha-DSP-A1-Amps-manual/id/319ag811/t/2/
See Page 73 Troubleshooting.
Mar 06, 2011 | Yamaha DSP-A1 Receiver
Hey got a yamaha rxv650 amp in good nick that has stopped switching on. Been great 4 years love the unit, normally has that secondary click wen u push the on button but has just stopped. Any ideas and does...
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Feb 28, 2011 | Yamaha RX-V650 Receiver
I have a yamaha m65 power amp. the amp lights up but the red protection light stays on. no sound.
the power amps are blown and need replacing, the protect circut is stopping any further dammage
Oct 06, 2008 | Audio Players & Recorders
Yamaha P2500S Amplifier Logo
869 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
