Question about WELA electronic Ge Smart Home 8 Zone Indoor Outlet Receptacle Receiver
Our home has a outlet that keeps blowing the breaker
Our home has a outlet .the tester we pluged in showed a hot neutral reverse . what does that mean
You have to reverse it and call an electrician for help...or better yet replace the breker fuse to a higher amperage,or change the wire size or rewire it and install a new breaker with a higher amperage....have a nice day!
Posted on Feb 03, 2010
Testimonial: "Thank you we changed the outlet it seem to help the problem "
Breaker keeps going when plugging the cord in the outlet
the outlet itself may be miswired with the line(hot) and neutral reversed. simple plug in tester will tell you if that is the issue, among other things. usually under $4 for the tester.
Aug 06, 2015 | Frigidaire Heating & Cooling
Outlets do not work, circuit tester says Hot/ground reverse but all connections appear correct, circuit is on an arc arrest breaker.
Move wires to different breaker with same amp rating?
Try different tester?
Test wiring box-by-box to locate the reversed connection.
http://waterheatertimer.org/Basic-house-wiring.html#loose-wire
Check each box for Hot and neutral:
http://waterheatertimer.org/Basic-house-wiring.html#test
Gene
Nov 11, 2014 | Electrical Supplies
Why does the unit beep after it is pluged in.
Most new window units have a ground fault circuit. More than likely, the outlet you are using is Not grounded or the Neutral and Hot side are reversed. They make a tester you can purchase at most home improvement stores. I would go buy one and test the outlet. You could have other outlets with the same problem. You have to use a 3 wire outlet. Large side of outlet=neutral, small side of outlet=hot, round or arched hole=earth ground.
Jun 12, 2014 | Frigidaire FAM187S2A Air Conditioner
How to fix hot/ground reverse outlet
The black and the white wires on those plugs are reversed. Turn the power off for those plugs, and swap the wires. The black wires go to the brass colored screw, and the white wires go to the silver colored screws.
Jun 01, 2013 | Electrical Supplies
What does "open neutral" mean?
The "neutral" wire in home wiring is always the "white" wire. The hot line is always the "black" wire or in the case of a multiple conductor, can be just about any color but white or green. Green is circuit ground, the nasty 3rd pin on the plugs we use, but a very important safety feature.
When you have an "open neutral" reading it means that the "white" wire has come loose some place in your wiring. A broken or loose wire is referred to as an "open" in electrical terms. I assume you are plugging an outlet tester in and get this indication. It may just be in the outlet you are testing or someplace else between the outlet and the circuit breaker.
Sep 12, 2010 | Sperry Instruments Measuring Tools &...
THE MAIN FUSE KEEPS BLOWING AND THE TV WON'T GO ON.
You should check to make sure that your wiring is correct in the residence. An outlet tester is available for about $5. The wiring could be hot/neutral reversed which won't affect anything except computers and set top boxes of all kinds.
Jun 14, 2010 | Vizio GV42L 42 in. LCD Television
Microwave fuse blowing???
You really need to check that circuit for ground and neutral faults before using it again.
Aug 29, 2009 | Panasonic NN-H275 Microwave Oven
What does open neutral on my gb circuit tester also hot/ground reversed mean
An open neutral means that neutral, or common wire is not connected somewhere. If for example you test a outlet in a room, and the tester shows that you have an open neutral, Then somewhere along the circuit the neutral is not connected properly. In rooms most outlets are connected in series to each other, so if you have an open neutral in one outlet, it can affect all the other outlets too.
Hot/ground reversed means that the hot wire and the common wire are installed in the wrong order.on the outlet,you have a hot side (black wire)and a common side(white wire)and the hot wire is installed on the common side instead of the hot side and the common is installed on the hot side.This show up on the tester this way because the common and ground tie into the same bar in the panel.
Fix the open neutral first as this can show incorrect reading on the tester on all outlets after the open neutral.
Aug 03, 2009 | Gb Electrical Electrical Supplies
Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
Dec 27, 2008 | IDEAL MCM TESTER GFI CIRCUIT
WELA electronic Ge Smart Home 8 Zone Indoor Outlet Receptacle Receiver Logo
Top WELA electronic Home Security Experts
Lawrence Oravetz
Are you a WELA electronic Home Security Expert? Answer questions, earn points and help others
