Rheem heat pump schmetic wiring diagram for model RPKA-036JAZ
tborn6
  • 700 Answers
SOURCE: Need wiring diagram
here would be the hook ups that are needed. at the air handler
r-red
g-green
c-common
w1/w2/aux-white (DEPENDS ON WHAT TYPE OF SYSTEM YOIU HAVE)
then these are what goes to the outside unit
y-ylw
o- org/or b-blue
c-white
r-red
personally contact me if yopu still have questions. thanks
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Posted on Jan 05, 2009
  • 1253 Answers
SOURCE: outside fan runs constantly Aux Heat only 50%
Let's start out by your statement that the fan would not run, then you changed the contactor, not it won't stop running.
I believe, based on your info, here's what you need to do. Kill power to the unit. The 2 wires bringing power to the outdoor unit should be on the top 2 terminals. The 2 fan wires should be on the bottom 2 terminals. This is providing that the contactor is mounted Vertical. The could be an outside chance that the unit has a short in it and you are getting voltage feedback somewhere.
Take another look.
Posted on Dec 31, 2009
  • 288 Answers
SOURCE: Rheem Heat Pump outside fan seems to be running
no this is not normal. the fan should stop running when the thermostat is satisfied or when the heat pump goes into defrost mode. if it is running nonstop, there is a contactor that operates the fan and compressor that if it sticks will get line voltage to it. you would have to take the cover off of the outside unit and turn the thermostat to off. If the fan continues to run, you need a new contactor.
Posted on Jan 13, 2010
  • 588 Answers
SOURCE: Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Posted on Mar 16, 2010
Rheem RPKA-030JAZ MAKES A HARD KNOCKING SOUND
sounds like it's running backwards. possibly need a time delay in the condenser. make sure your drain line is clean.also inspect low voltage wires for bare/ chew spots near outdoor unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 12, 2017 | Heating & Cooling
Wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Apr 13, 2010 | Heating & Cooling
Rheem Heat Pump outside fan seems to be running 24 hours per day. Outside temp 23 degrees. Is this normal? Model #RPKA-018JAZ
Jan 13, 2010 | Heating & Cooling
Outside fan runs constantly Aux Heat only 50%
Take another look.
Dec 30, 2009 | GE Zoneline AZ55H09D Air Conditioner
I have a RHEEM heat pump.Model# RPKA 025 JAZ. Problem- ac side works fine heat pump side unit goes into compressor lock after head pressure pegs out over 500 lbs with in 60 sec.
there is a huge problem in the reversing valve. if it works in cooling, there should be no restrictions that would cause that kind of head pressure. the reversing valve is the only thing that could cause this restriction since a/c side works. It is not repairable.
Dec 11, 2009 | Heating & Cooling
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
Rheem thermostat wiring diagram
The only thing different about a Rheem unit is on the heat pump they use B instead of O. RYGWC all the same.Rus
Jul 16, 2009 | Heating & Cooling
Heating & Cooling Logo
1,227 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
