Question about Kenmore Sewing Machines
I have a Kenmore sewing machine,model 117.600
I have a Kenmore sewing machine, model 117.600 missing a presser foot. Where can I find one
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
  • 152 Answers
SOURCE: The feed dog is not grabbing the material or the
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Posted on Oct 23, 2009
  • 980 Answers
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Posted on Nov 04, 2009
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
http://makeitsew.biz/presser-foot-pressure
Sewing Machine Pressure Settings for Machine Quilting
Dec 20, 2016 | Kenmore Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
I have a Sears Kenmore sewing machine I want to get a 1/4 in presser foot for it, is there one and where would I get it/
You first need to determine which shank the presser foot uses on your machine. You can compare your shank (current presser foot) with these photos to see which one your machine uses.
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
NOTE: If you purchase a snap-on presser foot, you will also have to buy a "shank adapter" that will attach the presser foot to the needlebar. Here are some pictures of snap-on adapters:
Kenmore sewing machine snap on adapter Google Search
However, you will still need to make sure to buy the correct adapter for your machine. The GREAT thing about buying a snap-on adapter is you can add a lot of presser feet to your sewing machine accessories because you can purchase additional snap-on presser feet or even a complete set of snap-on feet that will all work with your adapter and your machine!!!
Kenmore Presser Feet eBay
You will just snap one foot off and snap another on!!! Great idea!!!
OR--you can take your current presser foot along with the make & model of your machine and check with the local sewing repair shops to see if they have what you need.
FYI, once you know what shank your machine has, you can probably also find other specialty feet for your machine, ie walking foot, free-motion foot, etc.
Jan 17, 2016 | Kenmore Sewing Machines
I have a Kenmore model 158.19411 and I want a walking foot for this model. Is this model a high shank or low shank?
The Kenmore 158.19411 uses super high shank presser feet. Sears Parts Direct has the zipper foot still available for the 158.19411. http://www.searspartsdirect.com/kenmore-sewing-machine-parts/6759/0020/158/model-15819411/0582/1220000.html . Other compatible feet are available here: http://www.sewingpartsonline.com/kenmore-158-18023-sewing-machine-parts.aspx . This site also has an adapter for connecting Kenmore-compatible low shank presser feet to the Kenmore 158.19411 .
I hope this helps.
Aug 23, 2015 | Kenmore Sewing Machines
How can I find accessories for an old machine?
Sewing shops are loaded with this stuff. You can order online too. You'll need the make & model number. Do a little research, I think Kenmores are simply repackaged Singers.
Aug 05, 2015 | Kenmore Sewing Machines
Need to replace an ikea SY sewing machine presser foot
try these sites
ebay
contact these sites and call or email them
sewvacdoctor.com
a1sewingmachines.com
Apr 07, 2014 | Kenmore Sewing Machines
Pressure foot holder is missing
It's presser feet and not pressure feet.
I am not sure what you are asking for. Look through these to see if you can find what you are looking for - http://www.sewingmachinesplus.com/sewing-feet.php
Mar 10, 2010 | Kenmore Sewing Machines
Sewing Machines Logo
311 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
