Question about Dell 946 All-In-One InkJet Printer
I have a Dell 946 scanner which works fine when pages are placed flat on the screen. However, when I use the sheet feeder for two or more pages it creates huge files -- too big to email even!
  • 105 Answers
SOURCE: Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Posted on Mar 27, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Dell 946 printer
You need to set the size of your page on the printer preferences.
If you need more help you can see the manual of your printer here: http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Posted on Sep 24, 2008
  • 523 Answers
SOURCE: scan to email does not work dell a960
well scan to email or file depends on the setting your putting if its right or wrong, the machine should be hooked to network and has ip address, browse the ip address of the machine and setup the information, and try it.
Posted on Jun 17, 2009
pineworks
  • 4041 Answers
SOURCE: My dell 946 printer prints out blank pages but ink
Hi there
Just some thing for you to try.
First make sure you got the printer driver handy, then close down the PC and restsrt and reinstall the printer driver back, and dont put the Usb lead in till the software asks you to do so.
All the best Pineworks
Posted on Apr 30, 2010
SOURCE: Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
Posted on May 03, 2010
Why my Dell 946 printer wont print
Have you installed the printer driver? If you did and it won't print....uninstall it and reinstall the driver.
Jan 04, 2017 | Dell 946 All-In-One InkJet Printer
How i can scan multiple pages in one file ??
You need a document feeder. The printer has on or it doesn't. If it does you usually place the documents face up in the overhead feeder and the scan sensor in the printer will detect a load of paper in the feeder and choose to there instead of a single sheet under the glass.
Apr 17, 2016 | Artronix Technology Artec ViewStation AS6E...
I want to know how to use the scanner - we have lost instructions
Instructions
    • 1 Determine if the scanner has flatbed only or ADF (automatic document feeder). Scanners with have a flat glass section for scanning, but they may or may not have an ADF. Determine if your scanner has one of those so you can scan one sheet or multiple sheets at a time.
    • 2 Place paper in respective slot. Insert the paper into either the ADF, or place on the flatbed for scanning use. Make sure the glass is relatively clean. If you're using the paper feeder, make sure the pages do not have staples or paper clips still attached.
    • 3 Press the "Scan" button or use an application on the computer that can interface with your scanner. Use this to grab the image of the documents or pictures you desire to be digitized.
    • 4 Save scanned item as you want it. Store the now digitized image to whatever format you desire (whether it is PDF, JPG or other). Keep track of where your storage location is so you may retrieve the data soon.
    • 5 Retrieve it. Remove your papers, and browse to your digitized documents.
This is picture guide visit this site.
http://www.dummies.com/how-to/content/how-to-use-a-scanner.html
May 19, 2011 | Computers & Internet
What does the ADF input tray do? and how do i use it ?
Place the documents in the tray, face up.
If you want to copy them, then press copy.
If you want to scan them, then press scan or you may have to open the Dell All-In-One Center to scan the documents to your computer.
ADF stands for Automatic Document Feeder.
The scanner bulb stays stationary and the paper passes over the light reading what is on the document.
Rick
Jan 10, 2011 | Dell 946 All-In-One InkJet Printer
THE UPPER UNIT FLASHES ON THE SCREEN WITH ERROR CODE 39,003,40;75554
On the Xerox 8560MFP multifunction, this error code 39,003 signifies a Scanner problem, specifically that the Optical Test has failed. the 75554 is your current page count on the printer.
The Scanner Assembly 062K22590 must be replaced. It is fairly expensive, but moderately easy to replace.
You should also order the Scanner Calibration Sheet 109K01910 to make sure that margins and contrast are correct.
The scan/ document section is broken into 2 main parts, the Scanner, and the Automatic Document feeder. The feeder section is probably working fine.
Good luck with that.
Dec 27, 2010 | Xerox Phaser 8560MFP Printer
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
My Dell 946 will only fax the cover sheet!
dell 946 will not receive a fax but will send a fax.
Oct 30, 2008 | Dell Photo 964 All-In-One InkJet Printer
Scanner Sheet Feeder Malfunction
Change the top pick up roller. Can be ordered through the Dell parts dept. takes about 30 seconds to change.
May 23, 2008 | Dell 1600n All-In-One Laser Printer
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Dell 946 All-In-One InkJet Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
