Question about Linksys Wireless-G Broadband Router
I had my linksys wireless=G hooked up and changed my location and hooked it up within a half hour and now I can't get it to work on here I called my internet pervider and they won't help me get this back running so I can use it with my lap top please be patient with me as I am new to this I have no cd with this as I got this from my son and he doesn't have it either what should I do
  • 2,260 Answers
Router set up
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 03, 2010
Loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
Feb 18, 2011 | Linksys WRT120N Router
Hello, i have recently got some turtle beach x 31s and they are great but my xbox connection keeps going. it will work again after a few minutes but then it will disconnect again. i have read that there...
This pertains to Linksys routers, but it applies to all routers
To change the router's SSID or the wireless network's name,
To change the router's channel, .
To enable the wireless security on the router, .
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
I get limeted access to internet
To change the router's SSID or the wireless network's name, To change the router's channel, To enable the wireless security on the router, Log ionto your router, 192.168.1.1
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware on Linksys
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
No connections with my wireless on asus g72
It is a hardware problem. The switch on the Asus G72GX is at fault. I own the same machine, and the switch will hard-lock the wifi and will not unlock it. The hot-key will not work either. It took me a very long time to get to the root of the problem. The only solution appears to be to switch the wifi off, power down (restarting didn't work for me), turn the switch on and then power up.
Dec 12, 2009 | ASUS Computers & Internet
Wireless goes off-on-off-on-off on!!!!!!
Not know what router you have, I send you the info from Linksys, but the steps work for all routers:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
Sep 23, 2009 | Computers & Internet
I have an internet connection with my linksys to my new PC but the problem is I'm not getting a stong signal for a wireless connection. Can you help?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | Computers & Internet
WRT300N wont connect wireless
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
Thanks, Joe
May 01, 2009 | Linksys WRT300N Wireless Router
Why does the linksys wireless router ''WirelessG: keep going off/
Apr 05, 2009 | Computers & Internet
Linksys rangeplus drops wireless connection ever 5-10 mins
Thanks, Joe
Feb 19, 2009 | Linksys Ultra RangePlus Wireless Routr...
Linksys wrt 160n v2
If i was you I would hit the reset button on the bottom and sync all the computers and it should help.
Jan 20, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
