Question about Dell E173FPc 17" TFT LCD Flat Panel Monitor
Replaced the capacitors, but still the same problem
Hello, I have replaced the 6 capacitors showed on http://www.ccl-la.com/LCDrepair8.htm, but still got the same problem.............. LCD goes on for 1 second en then goes off and the button is green
  • 585 Answers
Check your soldering, and also make sure that you didn't leave any stray solder, like a splash, where it could cause problems. Clean your work with a solvent to get a good look at your connections. Flux can hide a solder bridge.
Posted on Feb 03, 2010
  • 11,361 Answers
Did you check the four transistors that drive the inverter transformers for shorts?
http://www.josepino.com/?howto-repair-dell
Dell gx270 motherboard can not power up no screen and no any sound but cpu fan ok.
The GX270 units have a known issue with failing capacitors on the motherboard. You can check out this article on our web site that explains what capacitors are and what they look like when they fail. http://www.ccl-la.com/blog/index.php/capacitors/ Ob the GX270 boards you will need to replace 18 capacitors. Open your case and look at the capacitors between the CPU and the aluminum heatsink and also the capacitors by the memory chips. The bad ones will have bulging tops. We carry the capacitors that you will need for the repair $20 or we can do the repair for $35 plus return shipping. You can contact us at tech@ccl-la.com if you need more information.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 20, 2010 | Computers & Internet
Tv will not turn on and has a blinking red light - no response from mauel or remote - simply blinks
hello,
This type of power problem is usually caused by a failure in the power supply. Typically the failure is capacitors on the power board. What happens is heat builds up in the TV case and the capacitors overheat, this causes them to bulge and short out. When they fail the power supply can't stabilize the voltages so it keeps resetting and trying again. If you can solder then you should be able to do the repair yourself. Check out this article on our web page: http://www.ccl-la.com/blog/index.php/capacitors/
This will explain what the capacitors are and what to look for to get replacement parts. If you don't want to do the repair yourself we do offer a repair service, info on this can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/ Feel free to contact us at tech@ccl-la.com if you have any questions.
Buddy
Corporate Computer
www.ccl-la.com
Apr 18, 2010 | LG 32LX1D 32 in. LCD Television
Screen is black, audio works fine
This usually indicates a failure in the backlight power supply. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ that explains what goes out and what will need to be replaced to complete the repair. You can also post a few pictures of the power boards to our forum section at: http://www.ccl-la.com/forum/index.php Our techs will then contact you about the parts that have failed. If you don't want to do the repair yourself we do offer a repair service, that information can be found here:http://www.ccl-la.com/blog/index.php/service-request-form/
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | Samsung T220HD LCD Monitor
Power comes on but no picture, something about capacitors? polaroid flm 3732
Yes,
The power on but no picture is a symptom of a failure in the power supply. If you want to do the repair yourself then check out this article on our web page: http://www.ccl-la.com/blog/index.php/capacitors/ The page explains what goes out and what will need to be replaced. If you don't want to do the repair yourself we do offer a repair service for $40 plus shipping. If you would like us to do the repair then use this link to request service: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 05, 2010 | Polaroid FLM-3732 Television
Wont turn on
This indicates a failure in the power supply. The most likely cause of failure is blown capacitors. We have an article posted on our web page at: http://www.ccl-la.com/blog/index.php/capacitors/ The repair will require replacing a few parts on the board and they will need to be soldered. If you don't want to do the repair yourself we do offer a repair service for $45 plus shipping. If you would like to setup service then use this link to our site: http://www.ccl-la.com/blog/index.php/service-request-form/ We have a 2-3 day turn around time for repairs. If you have any questions please contact us at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Mar 05, 2010 | iLO 3200 32 in. LCD Television
Blue light flashing
The flashing power light indicates a failure in the power supply. The repair is easy if you can solder. Check out this article on our web site about what needs to be replaced, http://www.ccl-la.com/blog/index.php/capacitors/ If you would like to take a few pictures of your power board and post them on our forum, we can mark the parts for you to replace, that section is at:
http://www.ccl-la.com/forum/index.php If you need parts then contact us thru our web site for a parts quote. If you don't want to do the repair yourself we do offer a repair service, use this link to request service -
I hope this information helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Feb 28, 2010 | AOC Monitor
Need to replace all capacitors in my 225BW. Need
The 225BW monitor uses the same capacitor kit that the 214T monitor uses. You can order the repair kit at:
http://www.ccl-la.com/LCDrepair4.htm The kits run $12 including shipping. If you don't want to do the repair we do offer a repair service for $30 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jan 31, 2010 | Samsung 225BW LCD Monitor
The backlight flickers when first started up, The flickering is pervasive, but only lasts about 10 minutes or so. I worry that the light is going out. Is this something that I could replace? I have...
I would check the capacitors on the power supply board first. This is the most common problem with LCD monitor after a year or two of service. Open the back and look for bulging capacitors, replace any that you find and you should be back going again. Check our web site at: www.ccl-la.com/capacitors.htm for pictures and information about this common problem. If you need to get parts or have over questions let us know at tech@ccl-la.com.
Buddy
Corporate Computer
www.ccl-la.com
Jan 15, 2010 | Acer AL1912 19" LCD Monitor
Power light blinks but will not turn on or off no video,tried a different computer same problem
The problem you have is a blown backligh inverter circuit. If you can solder then you should ba able to do the repair. We have a repair guide on our web site at: www.ccl-la.com/badcaps.htm The repair involves replacing 2 transistor, a fuse and 2 capacitors. If you have any questions just let me know. if you don't want to do the repair yourself we do offer a repair service for $35 + return shipping.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 19, 2009 | Acer AL1916W 19" LCD Monitor
The monitor on shows black screen only
Hello
We sell a full parts kit that comes with both 40T03GPs and the pico fuse that needs to be replaced and the 2 capacitors, the kit runs $16.00 and free shipping. If you want to purchase one go to:
www.ccl-la.com/LCDrepair1.htm , that link also has the repair guide showing where the fuse and caps need to be replaced.
Buddy
Corporate Computer
www.ccl-la.com
Jul 14, 2009 | Acer AL1916W 19" LCD Monitor
Dell E173FPc 17" TFT LCD Flat Panel Monitor Logo
202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
