Question about Sharp UX-P115 Plain Paper Thermal transfer Fax
How to clear Memory in Sharp UXP115
I get junk faxes all the time, so I don't put paper in so it won't print. However, the fax is still in memory.
What I want to know is how to clear the memory so I won't waste ink printing junk fax mail.
  • chaos88 Feb 29, 2008
    Thanks for trying Marsrover, but this is memory from received fax pages, not transmission pages. I do not want to transmit anything.
    When I press the start button it will tell me to insert paper in order to print them out what is in the received fax memory, which is NOT what I want.
  • Anonymous Sep 01, 2008
    Sharp Fax FO 885. Memory full. Wish to erase received fax memory.
  • 682 Answers
FIRST:1-PRESS START/MEMORY KEY IF YOU WANT TO TRANSMIT THE PAGES WHICH STORED UP TO THAT POINT IN MEMORY THE REMAINING PAGES WILL BE REJECTED FROM THE FEEDER.AFTER TANSMISSION THE MEMORY WILL BE CLEAREED.AND YOU CAN TRANSMIT THE REMAINING PAGES.YOU NEED ALSO TO TRANSMIT THE PAGE WHICH WAS BEING SCANNED WHEN THE MEMORY FILLED UP.
PRESS STOP IF YOU WANT TO CANCEL THE TRANSMISSION.
Posted on Feb 29, 2008
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
I have a fax in the memory and don't know how to print it
Press [START/MEMORY] and the stored documents will automatically print out. If you need the step by step owners manual with pictures, please send me an email to lbrown18062@hotmail.com. Please put "sharp ux b700" as the subject.
Jun 15, 2012 | Sharp UX B700 Plain Paper Inkjet Fax
How do I clear the memory and stop the print..
Surely I can clear the memory without wasting a stack of paper! But how?
May 26, 2010 | Sharp UX 300 Plain Paper Thermal transfer...
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Print from Memory
Check and see if your fax has a power save button next to your LCD screen. Pressing it will store everything into memory or you could do a flash memory clear however you will lose everything that is stored in memory(RX and TX only). Press FUNCTION , 9,*,8,#,7 then press start, next press your # key to scroll to flash memory. Press start. This should fix it.
Apr 23, 2008 | Sharp FO 5550 Plain Paper Laser Fax
How to Clear Memory in Sharp Fax UX P115
call sharp tech support (905 568 7140) for instr. they are very helpful and will guide you thro' the deleting memory process in madel ux-p115.
thanks
lk
Apr 11, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
UX A460 Paper Jam during fax reception how do I prinmt from the memory
open the machine and clear the paper jam and then closed.The machine will start printing again.
Oct 17, 2007 | Sharp UX 108 Roll paper Thermal Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Open Questions:
After I plug in power cord and telephone cord of fax machine to use it, dispaly starts flashing numbers, often going back and forth between 2 numbers, like 19 and 20 or 20 and 21, etc. I have never se machine get dial tone insert item to be faxed, and finally enter fax #, I hear the tones of the #'s I enter over the dial tone which continues and machine does NOT "dial" or make the call. The other odd and new thing since my last successful use of fax machine a few weeks ago after which it was unplugged and put away (standard for me as an infrequent fax user), is that now the display shows alternating numbers such as 20and 21. Later it may be 24 and 25. No information in manual regarding this. SInce the last fax use was to receive a lengthy fax while machine was unattended and I ran out of paper, then replaced paper and got rest of fax, I wondered if that event had triggered this and if there was some memory issue. Again, machine ahd been unplugged after that seemingly successful fax use. I did check memory now and found it to be 0.0& which is to be expected since machine was unplugged . And I do think that I got all the pages of that fax froma few weeks ago. Any ideas for the sudden change? Has not been dropped. Also did find that machine had set itself to pulse dialing although it has always previously been on tone which is its factory setting. So I have manually reset it to tone.Again this is mentioned as another oddity in association with current fax machine dysfunction. Any ideas anyone? Thank you!!!
Mar 02, 2017 | Sharp UX-P115 Plain Paper Thermal transfer...
See all Sharp UX-P115 Plain Paper Thermal transfer Fax Questions
Sharp UX-P115 Plain Paper Thermal transfer Fax Logo
322 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
