Question about Diamond Multimedia ( VC500) Video Capture
One-touch VC500 Diamond capture card isn't working!
I recently bough a Diamond multimedia one-touch capture card, I installed everything and plugged everything in. However, nothing comes up on my laptop screen when I open my one-touch video capture screen. It's like it is not giving off a signal between my TV and capture card.
The capture card lights go on, and the blue light triggers when I push the record button, but still nothing comes up on the screen.
Also I'm on Windows Vista 32 bit.
Any help would be appreciated!
  • 7 more comments
  • RaiderDawg Feb 03, 2010
    It didn't read my device.
    How do I cross check my connections?
    How do I cross check connections? It didn't read my device.
    How do I cross check connections? The connection is between my Samsung 32 inch HD TV, and my laptop. What else can I possibly do?
  • RaiderDawg Feb 04, 2010
    My tv has 4 sources, PC, TV, AV, and Component. The only 2 sources that are at use are the TV and Component. AV has nothing on it....how do I fix this?
    I did the second step and still doesn't work...
    I have EVERYTHING installed.
    My tv (which was made in 2009) only one set of red, yellow, and white cables. And on top of that it is green blue and red. On the side of the green blue and red, it is just white and red. The bottom set of cables goes to the capture card, the green blue and red goes to my Xbox 360.
    Am I supposed to have it on AV for it to get a signal?
  • RaiderDawg Feb 05, 2010
    Thank you so damn much! It worked! How can I leave you good feedback?
    THANK YOU SO MUCH AGAIN MAN!
  • Anonymous Mar 11, 2014
    Leaking around where espresso comes out
    1az-fse rav4 just shut off while driving won't start ever since fuel pump good but no spark
    leaking after removing to make a 2nd
    President:
  • 1,015 Answers
The video capture cables will need to be connected to the video and audio output connections of your television. They will say "video output/audio output" or "monitor output". If your TV only has audio outputs and no video output then you will need to connect the video capture cables to the output device you are trying to record from. For example: if your cable box has more than one set of video/audio output connections then you can connect the capture connections to the cable box to record whatever channel the cable box is outputting. If the cablebox you are trying to connect to only has one set of audio/video ouputs then you can purchase three RCA jack splitters that will turn one jack into two so that you can hook up the cable box to your TV and your capture card at the same time.Yellow jack is video. Red and White are left/right audio. Let me know if you have more questions.
Posted on Feb 04, 2010
  • muebe Feb 05, 2010
    You are very welcome. You should be able to leave a "testimonial" for me if you like. All positive comments are much appreciated! There should be a link or a button to leave one.Thanks for using FixYa.
  • 265 Answers
Make sure you have installed required video codecs such as MPEG 4/3/2/1.
  • 6,993 Answers
After you have the connections, cross check again and follow the steps below;
  1. click Start menu of your laptop
  2. scroll to 'Control panel and click
  3. after control panel has opened click "Power option" icon
  4. Once it has opened, look down the left side of the screen, you would see "Windows mobility center", under "Personalize"
  5. Click the widows mobility center and a dialogue box will come up
  6. from the dialogue box, look out for "External Display"
  7. Click the external display and it will automatically search for connected devices.
If it does not see you device, then you have to cross check your connections.
Take care
Posted on Feb 03, 2010
  • Walesarumi
    Walesarumi Feb 03, 2010
    make sure the wires are in their right position, like, yellow (Video) for display and white and red for Audio. Also press the AV on the TV.
    Secondly, from control panel. click personalize, click display settings. you will see a bold 1 and 2 display box, drag the box 2 to box 1 and press ok.
    Try this, take care.
Diamond VC500 Capture Card Wont Record!?
Windows bugs... I would first remove the card and software and then reinstall. Update drivers under system devices. Try again. There may also be a menu to enable recording, allocate hard disc usage for recording etc.
Sep 05, 2012 | Diamond Multimedia ( VC500) Video Capture
No signal from Diamond VC500 Capture Device
I have a similar problem. Sometimes it works fine, but it will often have sound but no picture in the box. Other times, there is no input signal showing when I click on the gear wheel to adjust settings. There is no rhyme or reason to the missing picture. Whe I play it back, I do have the picture - usually.
Jul 18, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Jan 20, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
How to set up one-touch video capture vc500
You can use either the S-video or the RCA video connector. I don't think you can use both at the same time but I haven't tested that. Also, if you use the S-video adapter, it has no audio so you also have to use the RCA audio connectors when using S-video. Hope that helps...
Aug 26, 2008 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
1,181 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
A Vlad Fuica
Level 1 Expert
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
