Question about Pioneer Car Audio & Video
How do I remove the stock radio from my 2001 toyota 4 runner?
    Sergeant:
  • 306 Answers
Disconnect the negative battery terminal to
prevent an accidental short circuit. Open
the center armrest door. Unclip the parking
brake trim panel. Unclip the gear shifter trim
panel and remove the panel. Remove the
climate control knobs. Remove the climate
control trim plate and (2) Phillips screws
exposed. Unclip the dash trim bezel and
remove. Remove (4) Phillips screws
securing the factory head unit and
disconnect the wiring.
Posted on Feb 07, 2010
99 Toyota 4 runner 2 wd front wheel removal
Install front wheel bearing hub assembly on a ... - YouTube
? 8:42
https://www.youtube.com/watch?v=LQ-DGdt2J2U
Mar 11, 2014 - Uploaded by Andy Taylor
... Install front wheel bearing hub assembly on a 2003-2014Toyota 4Runner .... Pressing a 2005 and up Toyota Tacoma,4Runner, FJ Cruiser 2WD or 4WD ... How to Remove & Replace a Toyota 4x4 Manual Locking Hub ...
images for 99 Toyota 4 runner 2 wd front wheel removal
Nov 26, 2015 | Toyota Cars & Trucks
What is the 2001 4runner Premium Stereo wiring diagram?
stock? or non stock?
stock cars have like 2 to 6 radio options, all covered in the FSM
"factory service manual" (helm.com)
or at alldata.com, DIY for $15 access.
if non stock visit your cars radio maker web site. get manual. free.
same answer for all cars.
or go to any car store, buy the radio harness connector kit.
in kit is drawing that , bingo names each wire. and color.
all cars made same answer.
posted like 100 times now,... so... search.
Feb 11, 2015 | 2001 Toyota 4Runner
Changed air filter in 1995 toyota 4 runner and after putting air box back together the 4 runner won't start
does the vehicle crank? if it does please remove the old air filter and leave the air filter intake box open, unplg the maf sensor, try and let me know.
saif
Apr 01, 2014 | 1995 Toyota 4Runner
Trying to install a new radio into my 95 toyota 4 runner but the wire colors in the car and ione ones on the radio don't match. how do i find out what wires to hook to what
if your truck still has the plugs from the stock radio you can buy a wiring adapter from walmart, if not you will have to test each one individually, black is always the ground red and yellow will be the power leads yellow is usually constant but test both with a test light or voltmeter with the key in the off position and the the on position to make sure. As for the speakers you will have to hook them up one at a time and make sure the sound is coming from the correct speaker. possitive and negative wires for each individual speaker will be the same color, but the negative will have a stripe runing down it. Hope this helps.
Mar 29, 2011 | 1995 Toyota 4Runner
Starter removal on a 1990 toyota 4 runner. Where
it is not fun w/o lift look behind passenger wheel you will need to raise front end remove wheel ,remove skid pan,and of course battery ends if 4wd I highly reccomend a lift good luck and please rate this
May 05, 2010 | 1990 Toyota 4Runner
4 runner check engine light
Find out why the light is on and fix it. That should aleviate the light problems.
Aug 27, 2009 | 2001 Toyota 4Runner
What is the brand/model of the stock spark plug for an 04 V6 4 runner? Heat range? Gap?
Toyota generally uses ND (Nippondenso) paltinum spark plugs. If you want to waste $20.00 each at the Toyota dealer then so be it, I put NGK's or Bosch plugs in my Toyota's, Honda's they're generally alot cheaper and just as durable may'be better.
Aug 24, 2009 | 2004 Toyota 4Runner
How can I disconnect the power antenna from my 2001 toyota 4 runner?
Does it keep running all the time and you just want it to stay up. They"re not that hard to replace.
The radio power triggers the antenna and the ant motor can be disconnected in the pass wheel well.
Jul 02, 2009 | 1995 Toyota 4Runner
Remove a driver side door panel on a 2000 Toyota Limited 4 Runner
remove the screws that hold the inside door handle and clips behind the door panel
Jun 14, 2009 | 2000 Toyota Corolla
To remove the stock stereo
Basically:
1: remove center console - 2 parts where the shifter is located... all of em use clips - just give it a nice pull and it'll pop off
2: remove driver side panel attached to radio console( 2 clips only)
3: remove screw found behind center pocket under a/c control
4: pop out a/c unit (4 clips - 2 on top 2 on bottom) just give it a nice pull... (was scary at first but easy and won't break anything)
5: pull entire front center panel (silver piece that covers radio/ac etc etc)
6: radio is attached via 4 screws - 2 on bottom - 2 on side
7: remove radio
8: make sure u have the AI install kit to install radio w/
9: reattach everything n you're done!
Jul 24, 2008 | 2003 Toyota 4Runner
Car Audio & Video Logo
75 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
