Can i link my amp (Beringer EP2500) to a Studiomaster Vision 8 powered desk. If so, would i link it the same way, straight from amp and into the main L & R outputs. Susan
    Champion:
  • 211 Answers
I'll think you can link your EP-2500 to the powered mixer, but absolutely not into the main outputs.
Look if there's a pre-output on the console, that is one way to connect your amplifier
The other way is the master insert connector, then you have to use a stereo jack and connect the amplifier to the ring and ground from the jack.
Good luck,
Gerard
Posted on Feb 07, 2010
Studiomaster powerhouse does fan come on straight away
If this is an amp, the main relay will come on right away, followed by the speaker relay within 5-20 seconds.
Apr 29, 2014 | Audio Players & Recorders
I have a studiomaster vision 8 powered mixer the
Probably you have a missing voltage at power supply which should be +15V/-15V connected to a number of opamps in the mixer section of the circuit, NOT in the power amp section, let me know to help troubleshoot your issue.
Nov 01, 2013 | Audio Players & Recorders
I have a hum/buzz when i turn on my studiomaster vision 8 amp, all the volume and channel sliders are down, i have had this problem before and it went away for a while and now its come back, i can play all...
Yes it almost certain to be the big Electrolytic Capacitors in the power supply. What you are hearing is the 50/60hz mains hum they are supposed to take out. Don't know the amp in question, but this is common problem with all amps. You can't miss these. But be care full they can hold a charge! There might be just one big one or more. At the least 2,000UF. Replace all.
Jan 26, 2011 | Audio Players & Recorders
I have a studiomaster powerhouse vision 8 and when i turn it on the displays says ''incorrect pin'', i have never had to enter a ''pin'' and wouldn't know how to, it has worked perfectly for absolutely...
I have just had exactly the same problem with my up-to-now totally reliable studiomaster powerhouse vision 8. It finally let us down at a gig after 15 years faithful service.
Does anyone know how to fix it?
Feb 06, 2010 | Audio Players & Recorders
Red light on permanently one 1 channel, that channel just buzzes
on beringer europower ep2500 if both clips lights is on chane d9 d10 d11 d12 and the two 220uf caps for the +15 and -15 voltage supply for the op-amps it a common fault alvan dawkins
Oct 24, 2009 | Behringer EUROPOWER EP2500 Amplifier
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
127 people viewed this question
 Grubhead
Grubhead
