Question about HP OfficeJet 4215 All-In-One InkJet Printer
I put in a new cartridge, but it won't print. I had taken the clear tab off over a month ago. If it's dried up, is there anything I can do to get it going again????
  • gingrichc Feb 03, 2010
    Your response was very prompt, and I tried the "worm" water, but it didn't work. I think they just got too dried out. It's my own fault, but thanks so much for helping. I'll just go to OD and get another one. Granny
  • 4,041 Answers
Hi
There is a place in your driver when you go to print a docs there are some tabs there which will have Tools Tab you can clean heads from there, if heads not clean then try some tricks I used
Here.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
Do refillable cartridges cause HP 3650 printer to not print????????
Get new ink cartridges. If they sit that long without being used the ink will dry out in the print head part of the cartridge and clog the very small holes. The clogs are inside the cartridge so wiping the outside will not clear the blockage. In the future if you have to leave the unit without it being used for over about a week you should remove the ink carts and put them in a sealed zip lock bag to prevent them from drying out.
Mar 28, 2013 | HP DeskJet 3650 InkJet Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Check ink cartridge on right
Yes - if they are not used they will dry up and be unusable.
Unfortunate but you need to replace them.
For future ref - IF they will not be used in 4 - 6 months
pop them out and put scotch tape on the head where ink comes out
and that should keep them good for several months..
I have done that and close to a year later - was fine.
Hope this helps :)
Sep 30, 2012 | HP Photosmart C4180 All-In-One InkJet...
One colour won't print. tried new cartridge but
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 12, 2011 | Canon PIXMA MP810 All-In-One InkJet...
HI: I am having trouble with my printer (Kodak) which I purchased about 6 months ago. I bought, and replace new ink cartridges (both black & color), and when I printed the first time, it came out...
hi, have you taken the clear plastic cover off the bottom of the cartridge where the ink comes out of, also remove the cartridges check for this little clear piece of plastic that needs pealing off if this is not on their or you have all ready taken it off then re-insert the cartridges ensuring they are fitted correctly.
Then try printing again and let me know what happens ok
Jan 15, 2010 | Kodak Office Equipment & Supplies
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
I got me a new kodak easyshare,and tried it out when i got a year ago,and i hooked it up,but it won't anything,i thought the ink was dried up,so i put all new ink in,but it still won't print anything,can...
Hi Ina,
Have you checked on the new cartridges to make sure there is no sticky tape over the print heads.
The manufacturers often put this tape over the print heads to prevent the ink from drying out or leaking out.
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer won't print yellow even when I replace the cartridge.
Desperate measures!
I have a PIXMA MP 750 and months ago my yellow ink stopped printing. I was only able to use the printer for black and white printing. Every once in awhile I would try multiple deep cleans, new ink cartridges, etc. etc. I talked to the very unhelpful folks at Canon who suggested a new print head ($70), but they couldn't guarantee this would actually work. They really thought it would be best just to buy a new printer.
Although I was feeling bad about adding yet another cheap printer to the landfill I'd pretty much decided to get a new printer. As a last resort I decided to use a suggestion I came across (at pcuser.com) to run hot water through the print head. It was easy to remove the print head (check your manual). I propped the head up in my dish drainer and ran hot water straight from the tap first through the end with the little circular parts and then through the end with the metal strips. I eventually used boiling water from the kettle.
As I poured water through one end I started to see yellow ink coming though the other end so I figured the ink had dried in the head. I kept pouring water through (from both ends) until the water ran clear. I dried the print head, put it back in with the cartridges and VOILA! after MONTHS without yellow ink it's working beautifully again!
If you've tried everything else and feel desperate enough to buy a new printer you might want to try this and report back.
Jan 16, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Lexmark x4270 Alignment Problem
When you say you checked to see if anything is obstructing the cartridge, please also make sure the clear tape/tab on the cartridge head was completely removed before use.
If you put another head in, does it work? Sometimes the cartridges are bad, if they have been exposed to extreme temperatures.
A fragment of the protection tab would explain the error as well as the printout, as you don't seem to have any yellow at all.
Hope this helps.
Jun 09, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
