Question about Pioneer PureVision PDP-504HDE 43 in. Plasma Television
Pic dissolves then tv switches off - Pioneer PureVision PDP-504HDE 43 in. Plasma Television
  • 3 more comments
  • smatharu Feb 03, 2010
    the picture image is frozen even though the sky box is not connected. It is of very poor quality, then the picture starts to dissolve and the screen darkens then it switches off. The light on the standby on tv flashes three times.
    stays on for 2 secs. the tv is 5 yrs old.
  • Harleen Nash May 11, 2010
    How long does the picture stay on? How old is this unit?
  • Alexander  Moore
    Alexander Moore May 11, 2010
    looks like overheating of power supply. make sure, you have good air flow to the set. it has a few fans, draws a lot of dust inside. First, need to open the set and see, if does the same with back opened. It quite a task, though.
  • Kim Yearick
    Kim Yearick May 11, 2010
    If you could supply more info I may be able to help. If you turn it right back on what happens? Does it flash or do anything funny before shutting off? It sounds like a short but we need to try to zero in on the location. Let me know the answers and I will see what I can do. hardrocko
  • 148 Answers
First off place a fan as close to the back of the tv you can, this will cool the tv's powerboard components, it might prolong your tv life for months.Now for the diagnosis and repair;The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not) then please rate, thank you!pic dissolves then tv switches off - 353c3a6.jpg
Posted on Feb 04, 2010
How to switch tv to play games
well there should be an option on your remote labled either source or input. that allows you to change from the iputs on your tv. you need to know which input you plugged your wii into. if you select the option and match your tv input to where you plugged your wii into and you still have no pic.make sure your wii is powered on. as well make sure you plugged the cables in correctly. if your using componet cables its red green blue for video and red and white for audio. make sure the audio and video are not crossed that will cause pic distortion. and if your using composite cables makes sure its red yellow and white plugged into red yellow and white. yellow is for video and red and white are your audio. if all this is correct and still no pic. then it's either your wii or your TV.
Aug 20, 2012 | Toshiba 30HF66 30" TV
Soap does not dissolve
see this possible causes;
Timer
test for defective
Bi-metal switch or wax motor
test the switch for open the cup detergent
Detergent cup, itself
detergent clogged, repair
May 08, 2012 | Bosch SHX68E05UC Dishwasher
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
1. After being on for 1-2 hours the pic goes out and turns to "the green screen of death". Pic will not come back on unless TV cools for 30+ min. 2. When I switch from DVD source to cable TV source the pic...
You got an issue with overheating.  TV is designed to shut off to protect electronic components if TV overheats.  Take it to the shop and have them open this thing up to identify the faulty circuit.  Also, check to make sure your not blocking the heat vents.
Nov 11, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Aquos LCD tv no pic or sound on HD tv
The tuner is one board but I wouldn't suggest anyone but a qualified technician to replace it.
Oct 17, 2009 | Televison & Video
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Aug 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Little big planet
you put a magnetic switch on it.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
How to
not applicable instead use windows picture and fax viewer in pc and den tranfer pic in iphone
Jun 01, 2008 | Apple iPhone Smartphone
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Zenith tv no pic
You have a picture when you're watching a DVD, but none when you're watching regular cable? Does the audio appear to be okay?? Are you sure you've switched the inputs on the TV back to main???
Let me know..
Bill
Dec 08, 2007 | Zenith B25A24Z 25" TV
Pioneer PureVision PDP-504HDE 43 in. Plasma Television Logo
80 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
