Question about Cell Phones
Call Pilot Mini 150 does not work. Dialing in does not work. Need for our guests! Lights on the left of panel light up. Lights on right do not. Have unplugged and replugged. No go
  • 1,868 Answers
Hello! When you first power-up, do LED lights #1 and #2 blink quickly?
Guru.............saailer
Posted on Feb 04, 2010
What must i do for tail lights and dash to work on F150 2006
You should check and / or replace the 15 amp mini-fuse. It is in location #6 on the fuse panel under the instrument panel. 15 amp mini fuses are blue in color. Usually, but not always, you can tell if a mini fuse is burnt out by removing it and looking through the clear plastic to see if the fusible link is intact or open (burnt).
If it is labled, it may read "Parklamps, BSM, Instrument panel illumination"
Below is an image map of the fuse panel for a 2006 F-150.
e203adf8-5a39-450d-9174-344d711f50e1.jpg 1b35e398-ef12-4b80-b105-ea7bc461f159.jpg 4b6d29f1-53eb-455a-8c59-a9f766410061.jpg
May 01, 2014 | 2006 Ford F-150
2004 Honda Pilot, right rear brake light doesn`t work. I know it`s not the light bulb because it works for the turn signal and hazard lights.
Chances are that is the bulb. Its a dual filament bulb. The brake portion of it is burnt out. try swapping it with the left side and see if it works then. If it works, get a new bulb.
Apr 17, 2013 | 2004 Honda Pilot
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
I need to know were to find the DRL Module for a 2003 F-150 4x4. My hi and low beem lights work ok , and the auto light sencor works . Its that my Day time running lights do not come on .
The wiring diagram does not show a stand alone drl module for the 03 f150. However it shows 2 drl
relays located in aux. relay box #2 located behind the right side of the dash, left of the glove box.
Also there is the drl resistor located behind the grill, right of the left headlight. Relay #1 is fused at
fuse #5-15a in the fuse block under the left dash. Relay #2 uses fuse #26-10a under left of dash.
Hope this helps.
Nov 17, 2010 | Ford F-150 Cars & Trucks
My running lights don't work
Did you check the fuse for the parking lamps ? This is in the cab fuse panel, Fuse # 6, 15A.
Do you have the Autolamp feature ( turn the main headlamp switch to the left ) ? If so, is this where the parking lamps are not working ?
If you turn the main headlamp switch to the park position ( 1 click to the right from off ) do the instrument illumination lights work ( dash / cluster & door switches if power windows ).
Aug 29, 2010 | 2005 Ford F-150
I have an 83 ford f 350 back lights and park lights and dash lights wont come on what could be the problem
Check the fuses for the parking lights and the backup lights:
Fuses Fig. 1: View of the fuse box located under the hood release lever, 1983 F-150 shown 85766098.jpg
Fig. 2: Unsnap the cover to access the fuse box, 1983 F-150 shown 85766099.jpg
On earlier models, the fuse panel is located on the firewall above the driver's left foot. On later models, the fuse panel is located on the underside of the instrument panel, covered with an access door. prev.gif next.gif
Aug 03, 2010 | Ford F-350 Cars & Trucks
Dear Experts, I am having problems with my heater.It's pilot light keeps on going out.Do you know what to do to help solve the problem? Thanks, Mystery Guest
light pilot, after pilot is kit hold valve button to keep gas manually coming out when valve is set to on pilot should stay lit, if pilot goes out right away you can gently sand thermocouple to clean foreign material off the end if this does not work thermocouple may need to be replaced.
Oct 27, 2009 | Heating & Cooling
Have a zephaire GL when you first turn on the
"sparks pilot lights" , "reset button comes on" can you be more specific on these terms you used? I know this posting is an old posting, but I maybe be able to help you as I have fixed all the problems (multiple with 6 G-L's zephaire. Here I'll try to "assume" your terms. The g-l has one light at the front panel. If you mean it comes on and off (the light that is), this is the due to continuous try ignition module, not reading the "flame sensor input right", assuming there is no flame at the pilot. This might be caused by a mulfunction of the ignition module, or by a bad "flame sensor wire" or sensor. See if the pilot spark / flame comes on when you turn the oven on. See if the white wire coming out of it is good and not chewed by rats or something. If the ingition control (the blue box) is reading flame sensor input right, it will light the main burners, (red wire on the valve) if I recall correctly. The ignition control works properly on max 150 F and the ventilation fan on top if it's not working should be replaced. They sell them on line, and also grainger has it for around $32. The o modules go for around $129 to 170. and sometimes you find them on ebay for around 50. Hope this helps.
H
Jul 13, 2009 | Blodgett Ovens
Pilot light will not ignite on my bosch 10p water wizard system
This process is best performed at night so you can see the pilot light in action.
Important...*ensure all hot water taps are off*
1) press and hold pilot button (extreme left button)
2) press spark button (extreme right button) while holding in pilot button from step 1
3) with the pilot button still held in, observe the pilot light through the window. if there is no pilot light now, your heater is busted.
4) if you see the pilot light above, very quickly *completely* remove your finger from the pilot button while at the same time pressing in the flame button (second from left - this button will not work until you completely remove your finger form the pilot button so timing is important) - the pilot light should stay lit.
5) if it goes out or your timing is off, repeat these 4 steps until it lights.
This could take a number of tries and can be quite frustrating until you can get the timing of step 4 right. Good Luck!
May 26, 2008 | Video Game Consoles & Games
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
