Question about Nokia N73 Cellular Phone
My N73 back camera auto opens at anytime, closes and reopens again without using the slide
  • nour94 Feb 10, 2010
    thanks i will check it
If you have tat problem then there is problem in your back panel if you change it your problem wil be solved
Posted on Feb 08, 2010
Very slow process and camera automatically on
Posted on Jul 17, 2010
Sir my n73 back camera auto without slider open plz help me
Posted on Jun 02, 2013
My n73 camera is automatic open please helpme
my nokia n73 back camra auto open any time please help me
Jan 29, 2011 | Nokia N73 Cellular Phone
2002 Honda Odyssey: sliding door jolts/reopens when closing
Please check the aft track roller assembly. It is easiest to inspect from the rear of the van looking forward when the door is open. You'll see the rear hinge assembly clearly. The track rollers cannot be seen but you can pull outboard on the rear edge of the door--the door should not move outboard more than 1/8 of an inch. If it moves out more than this or feels sloppy, suspect damaged/missing track rollers. This will cause the hinge to chatter in the track and "jolt". It will also cause the door to misalign during the close phase preventing the close motor from properly engaging.
Replacing this part is no easy task but doable if you are good with cars. Check back here for more details if you want to try it, otherwise get a competent mechanic or the Honda dealership to do it.
Jul 20, 2009 | 2002 Honda Odyssey
Nikon d40
If the camera is in auto mode, the flash opens anytime the camera feels that it cannot take the picture with only ambient light. You can overcome this by closing the flash once the camera opens it or using a manual mode. In manual mode, the flash opens only if you press the flash button on the left side of the flash housing.
May 22, 2009 | Nikon D40x Digital Camera
The door reopen by itself once its closed.moment later it reopen by itself it is very unreliable.
IF IT GOES BACK UP WITHIN 5 SECONDS OF CLOSING IT IS THE DOWN LIMIT.
IF MORE THAN 30 SECONDS SEE BELOW.
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Feb 22, 2009 | Skylink Group SkyLink GT-100 Garage One...
My automatic door on my van starts to close then when it is almost closed it automatically reopens without closing. I have looked and nothing is blocking it from closing.
Take a rag with rubbing alcohol and start wiping out all the creavas. Get it spick and span, those dern things are super sensitive a little peice of popcorn kernal will not let it close
Jul 29, 2008 | 2000 Nissan Quest
Camera problem
u mean when u slide ur sliding cover over ur camera then it remain in normal view and camera screen not appears on ur display...then t,it can be problem with ur camera switch or with ur sliding cover ,,, but if u have the warranty just return back it to nokia its is the best option for u caz they deal in best..to do so..
ok
Apr 15, 2008 | Nokia N73 Cellular Phone
Nokia n73 front camera not working
did you see the manual of your phone? please try to close the camera at the back then try to open the camera.
Mar 21, 2008 | Nokia N73 Cellular Phone
Shutter stuck, Won't reopen
start it, flick the lens really hard - restart it.. without opperating on it that is the only fix... you could sell it to mee too
Nov 28, 2007 | Canon PowerShot A540 Digital Camera
Nokia N73 Cellular Phone Logo
649 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
