Question about Whirlpool LER4634J Electric Dryer
Still running after two hours, then won't restart
  • 447 Answers
If it was running for 2hrs, I would say the high limit is blown. Small part, 2 wires connected to it,1,2 wscrews holding it in place. There is probably more than one. if you can check continuity, check them all. If none, replace it. I would start with the one near, if not in the element area.
Posted on Feb 03, 2010
Compressor dosen't restart
replace capacitors might be going off on safety.
Jul 21, 2013 | Dometic Rooftop RV Air Conditioner
Car intermittantly shuts off and won't restart for an hour or two
I owned a 1988, Oldsmobile 88, that did that. after several hundred $ of "repairs" - It was that pump IN the gas tank that had gone bad.
Apr 27, 2017 | 1999 Ford Taurus
1993 Oldsmobile cutlass ciera is stalling and won't restart after engine is turned off
Two thing, maintenance will be first[tune up,fuel filter,air filter].Second could be crankshaft sensor.
Mar 14, 2013 | 1989 Oldsmobile Cutlass Ciera
DC07 Shuts Off, won't restart
If it was running for a while... It may be overheating. It has a reset: http://www.ehow.com/how_5943288_reset-dyson-vacuum.html
But maybe just let it cool for an hour or two and try it again?
Oct 07, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
1993 Toyota Camry won't restart after driving unless waiting hours. The starter doesn't try and it's brand new. It always starts cold and if you don't drive it, you can turn it off and restart it over
i'me asumeing the batt is ok....turn on lights, do they dim when you try to start engine? if not .bad selonoid on new starter..was it rebuilt? it happens. Billy Starr
Dec 27, 2011 | Cars & Trucks
My Cub Cadet 2130 has a Kohler Command 12.5 Hp engine. I have had a recent problem where if I shut the engine off after running for a half hour or so it won't restart. Today it died on it's own...
You most likely need to replace the ignition module. You should find it under the shoud next to the flywheel, just follow the spark plug wire.
Sep 18, 2011 | Garden
Have a '94 S-10 Blazer Tahoe 4X4 and it starts
My suspicion is a starter going bad. Sometimes when starters get old and worn they will start good when the engine is cold but not when the engine is warmed up. Did you perhaps notice that lately is seemed to drag when you tried starting, especially warm or it seemed to crank a little slower? I'd replace the starter. Hope this helps.
Aug 14, 2011 | 1994 Chevrolet S-10 Blazer
I have a YTH2454 three years old runs fine for about an hour then shuts off won`t restart until completey cooled down,i have used my leaf blower to clean engine , just today i put new air filter and screen...
the coil that attaches to the spark plug wire may need a replacement for usually when they get old the heat will make them weak after the engine is running causing a problem such as yours here
Jul 04, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Car runs fine till it is turned off
two things come to mind....
1- a electrical component may be heat sensitive and not function after turn off heat soak
2- your fuel pump check valve isn't holding fuel pressure in the fuel loop
Next time check for spark...if thers's spark it's a fuel problem
Mar 24, 2009 | 1997 Oldsmobile Achieva
Whirlpool LER4634J Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
