Question about HP LaserJet 2500 Printer
HOW TO GET METER READING? - HP LaserJet 2500 Printer
  • 231 Answers
Switch it on and load paper.
Press the red and green buttons together, and several pages should print out, test page, config page, and perhaps a EIO or network config page.
The second page should show the page count.
Posted on Feb 03, 2010
How do I wire in a amp meter please
amp meters are wired in series in a power circuit
that is to say cut the wire and attach each end of the wire to the terminals of the amp meter
you have to know the amps in the circuit to get an amp meter large enough to read the current or it will burn out
( a 60 amp meter for a 120 amp power wire is not right)
in that case you can get an amp meter that runs a resistance in the back of the unit and as volts and amps are directly related by reading the voltage drop across the resistance the current (amps) can be read
That allows a small amp meter with a high face reading to be attached to a large current wire 10000 amps etc
you can also get amp meters that have a crab claw clip that goes around the power wire and by reading the flux field voltage converts that to an amp reading without touching the wire ( used by electricians to check current draw in electrical motors etc )
Apr 12, 2017 | Cars & Trucks
2002 Town and Country. Why does it have a rough idle, dies when stopping, has sluggish power, and sounds terrible?
Suspect throttle positioning sensor (TPS)...can be tested...need a meter set to read 5 volts DC...Tps is located on throttle body...it has a three wire connector with wire colors: Brown/Orange...Dark Blue/Dark Green...And Pink/Yellow...Engine off...Push points of safety pins deep into into rear of in place connector PLUS METER LEAD on Brown/Orange wire and NEGATIVE METER LEAD into DarkBlue/DarkGreen...Set meter to read 5 volts...Start engine...At idle (Yes, I know it is running rough) then read meter...RECORD READING...Next rev engine to full throttle...RECORD READING...First reading must be .08 volts...Second must be 4.5 volts...If second reading is less than 3 volts...example 2.4volts TPS is culprit...Replace TPS...all readings OK? Let me know...saailer
Jun 23, 2015 | Chrysler Cars & Trucks
How to stop your suzuki swift speedo meter??
Why would you need to? If its all electric then its locked in the memory.
Jan 25, 2015 | Suzuki Swift Cars & Trucks
Can this SWR be accurately be used for a boat VHF radio antenna? I have tied it and it seem to work but do not know if the reading are good.
Standing wave ratio is standing wave ratio. This meter is not reading based on frequency. It is reading based on the measurement of electrical energy. I see no reason why it wouldn't work.
Jun 22, 2011 | Astatic (PDC7) CB Radio
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
7310HP meter reading
THERE IS NO SPECFIC READING METER IN PRINTER BUT IF U WANT TO SEE THE USAGE JUST PRESS THE MENU BUTTON AND REMOVE THR PRINT LOG
BY PRESSING THE MENU
Oct 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
SQ FT meter reading
METER A is the square feet. METER B is linear feet
Jun 12, 2008 | Xerox Office Equipment & Supplies
Meter reading
PRESS THE C BUTTON AND WAIT FOR NO. TO APPEAR IN SHARP AL-800
May 16, 2008 | Sharp AL 800 Copier
Instructions for a swr meter/cb radio
An SWR meter is used to see how well your antenna is matched to your transmitter output, just like using the correct speakers with an amplifier.
There are usually two readings. FORWARD and REFLECT
or FWD and REFL
Firstly, make sure the antenna selector is in the correct position and set for the antenna you are using.
Next, switch your meter to FWD (FORWARD). Switch your transmitter to low power and press the microphone key.
Next, adjust the CAL knob for the maximum power reading, but not so far that the meter exceeds maximum!
Keep the microphone key pressed and switch to REFL (REFLECT). If your antenna is matched, the meter should now give a low reading. If the reading is very high, you must match your antenna by making adjustments or by using a matching unit.
A poor match will mean a poor signal. A very poor match can damage your transmitter and cause interference.
When you have a good FORWARD reading and a low REFLECT reading, your system will be reasonably matched and you can then use higher power. Remember that you will need to reduce the CAL knob to a lower setting when running high power.
Mar 05, 2008 | Computers & Internet
Meter Reading on Canon iR C 5870
if this is a greyscale copier you will only get b/w meter reading
Jan 09, 2008 | Panasonic Workio DP-4530 Copier
HP LaserJet 2500 Printer Logo
571 people viewed this question
Seeker5211
Seeker5211
