Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Error soak and scour light comes on wont wash
Our whirlpool dishwasher started getting weird a week or two ago.  i changed the control module it worked great for 5 minutes then stopped and soak and scour light comes on  cant reset   any ideas
  • bgbrobru Mar 09, 2008
    too late.  the boss decided we needed a new one.  Thanks anyway!
    Sergeant:
  • 351 Answers
Press and hols start button until it resets then try again.
Posted on Mar 09, 2008
Lights are blinking and nothing happens when you push buttons
Have you tried pushing and releasing the sani rinse button, then the heated dry? go back n forth several times. If that doesn't work try the soak and scour and hi temp wash buttons and re post results
Feb 20, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Clean light is flashing du1145 whirlpool dishwasher, will not run
This is a Common Problem. Read the same solution i offered to many Customer's and it actually worked like anything :-
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 11, 2010 | Whirlpool Dishwashers
Dishwasher will not run clean light keeps blinking
or
Hope i helped you.
Jan 10, 2010 | Whirlpool Dishwashers
Next Step
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
or
Hope i helped you.
Jan 08, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Clean light flashing 7 times.
or
Hope i helped you.
Jan 06, 2010 | Whirlpool Dishwashers
Clean light flashes, washer won't run
or
Hope i helped you.
Oct 07, 2009 | Whirlpool Dishwashers
Clean light flashes 7 times at a time.
or
Hope i helped you.
Oct 07, 2009 | Kenmore Dishwashers
Whirlpool Dishwasher Model GU2500XTPS1 Light on soak/scour button flashes on and off. Dishwasher will not run.
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
Nov 03, 2008 | Whirlpool Dishwashers
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
319 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
